Posted by Thomas Cooksley on 04/08/2020 11:47:08:
No confusion here Dave T has a Myford super 7 lathe but for some reason it's not working. In trying to be helpful can I ask why your lathe isn't working and is there any way anyone can help with that?
Tom.
Hi Thomas,
There are myriad reasons why it's not operational – I'm trying to avoid working on multiple machine projects.
It's an early S7 (1953) which I've got to replace the oil sight glass in the headstock (I've been playing with 3D printed parts), I can't turn one as there would be no headstock oil!
Leadscrew needs replacing cos it's very worn in the first few inches, but I do have a new one, but have to shorten because I have a gearbox.
I've had to replace the single phase motor and have installed a 3 phase motor with inverter but have yet to wire in the panel.
Replaced the headstock belt with a link belt, which won't clear or tighten so I've got to take the spindle out to put a proper one in – the list goes on but strip, clean and lube is a lot of it. Paintwork is in need of attention at the same time too!
Luckily I took early retirement mid July, but the jobs keep piling up
