Silly old duffer,
Yes, we took our responsibities very seriously, but we were not selling unmarked non compliant equipment, we were selling fully marked, supposedly compliant equipment supplied by the importer.
"You have to check that the manufacturer outside the EU has taken the neccasary steps."
How? They are in China, typical EU buck passing. surely the people setting the standard should also test for compliance, thats what the BSI used to do!!
"You must check that the documentation is available"
We did check, it was available., the fact that the paperwork was a work of pure fiction seems to matter little to the EU or the manufacturers, as the seem to have conspired to make the supplier responsible! That would not have been us, but our supplier, who was also the importer.
My point about mentioning the Grenfell tragedy was that it is a current example of something made in another country, sold in Europe (so it must be CE marked) and is obviously not fit for purpose, and non compliant with current regulations The building regs have a catch all regulation, which states basically that any work done to a building must not leave it in a less safe condition than it was before in the work was done………….fail.
"Then in a post mentioning the Grenfell fire, you confess to installing over-heating equipment that you believed to non-compliant. And furthermore that the company for which you were responsible decided not to have the power supplies checked because BSI charge a commercial rate"
WOT? When we bought it, it was fully documented and CE marked as compliant, after we had experienced the failures, all the PSU's were replaced FOC by our supplier, with more corectly marked and supposedly compliant psu's which also began failing. At this point the supplier recalled and replaced all the WAP units, and supplied a different type. We assumed that the BSI would be interested to know that an item marked as compliant to their standards seemed to be underperforming to the point of being dangerous, basically, they weren't, unless we paid them (A LOT). In the situation of an end user submitting a faulty or dangerous item to BSI, they would (at that time) have tested it free. Today they seem to be in the business of selling very expensive deemed to comply documents.
My whole point in this post was to try to illustrate that the Chinese will stamp their goods with any mark or number that is needed in the UK and Europe in order that it can be sold. They will also provide the neccasary paperwork on the same basis. To attach any credence to the validity of this marking and specification is the part that is laughable! There is no independant testing!! CE seems to make BSI more or less redundant, perhaps it will change when we eventually get out.
Phil
