Torsion Bar Steel
Torsion Bar Steel
Home › Forums › Beginners questions › Torsion Bar Steel
  • #7397
    John Bromley
      @johnbromley78794
      #171870
      John Bromley
        @johnbromley78794
        I have aquired a length of 9/16 square torsion bar from a broken tail lift.
        Before I go about destroying drills and milling cutters. Could someone tell me, can this material be milled/drilled readily or will it need some form of heat treatment to soften it?
        I'm guessing it is some grade of spring steel. It's a nice lump of stuff that I can get more of, if it's good.
        Bob Brown 1
          @bobbrown1
          There is a chance it is 5160 Steel and as is likely to be difficult to machine but once annealed should be reasonable.
          #171880
          John Bromley
            @johnbromley78794
            If I cut it into 6" or so lengths and toss them in my wood burning stove for a few hours and leave to cool, do you think it will soften them up?
            I might just try it, and do a before and after test drilling.
            Edited By John Bromley on 07/12/2014 22:09:07
            #171889
            Ady1
              @ady1
              Had a bit of broken 1 inch by 5 inch by 10inch leaf spring recently. The shaper dealt with it via both carbide and hss tooling. Only the outer skin was resistant so it was probbly a type of case hardened steel, like a sword, tuff skin only
              Edited By Ady1 on 08/12/2014 01:00:53
