Tom Senior M1 Vertical Head Drawing
Home Forums Manual machine tools Tom Senior M1 Vertical Head Drawing
  • #432792
    Bob Astill
      @bobastill76884
      Hi all i have managed to find a Vertical Head for my M1 tom senior all be it in bits and with 2 damaged gears these are being made now i really need a drawing to see what goes where i have found some photos and part numbers to get new bearings in a search but these are not great would any one have one please.
      I also need the seal number if anyone knows it?
      Bob
      #13666
      Bob Astill
        @bobastill76884
        #432824
        fishy-steve
          @fishy-steve
          Hi Bob,
          Which vertical head are you interested in? S type or knuckle head?
          Steve.
          #432828
          paul rayner
            @paulrayner36054
            Bob check your in box, also have you joined the tom senior group on yahoo, I used to be on that and the is loads of info on there.
            regards
            Paul
            #432846
            Bob Astill
              @bobastill76884
              Posted by fishy-steve on 11/10/2019 13:09:01:
              Hi Bob,
              Steve.
              Hi Steve not sure the difference between S type or knuckle but its just the small one it has no quill on it if that makes sense.
              i hope Paul will have the drawing i need.
              Bob
              #432852
              old mart
                @oldmart
                You may be able to get answers on the Denford forum. Denford own the copyright on all the Tom Senior archives.
                #432904
                Bob Astill
                  @bobastill76884
                  Posted by old mart on 11/10/2019 16:07:30:
                  Thank you i will have a look.
                  #432907
                  Bob Astill
                    @bobastill76884
                    Great site but still no blow up of the head their is a photo of the drawing i need lol so close but so far
                    #432909
                    paul rayner
                      @paulrayner36054
                      If I remember rightly the horizontal drive has bronze or oilite? bearings & the MT shaft has 2 bearings in it. 1 at the bottom which is held in place with the cover & the one at the top is held in place with a split screwed washer (the type you put a screw in so it doesn't come loose I don't know what you call them) there are no shims in there. You have to put the bearings on the shaft first and then slide the whole thing into the head.
                      your old bearings should have numbers etched onto them so you can identify them like that if all else fails
                      regards
                      Paul
                      #432916
                      Bob Astill
                        @bobastill76884
                        Posted by paul rayner on 12/10/2019 08:40:26:
                        regards
                        Paul
                        Thank you for that Paul i have found the 2 bearing numbers and the to thrust bearing one and have ordered them i now need the number for the Oil seal and i think we are sorted.
                        Bob
                        #432927
                        fishy-steve
                          @fishy-steve
                          Posted by Bob Astill on 12/10/2019 08:25:23:
                          Hi Bob,
                          The picture of the drawing is all I have. I managed to find it late last night. I was going to send it to you today.
                          I replaced the bearings in my knuckle head a couple of years ago. From memory the bearings were considerable more expensive than a metric equivalent.
                          If I had to change them again I might consider re-engineering the casting to take metric bearings.
                          Out of interest do you have a link to the bearings you purchased?
                          Steve.
                          #432938
                          Bob Astill
                            @bobastill76884
                            Posted by fishy-steve on 12/10/2019 10:57:47:
                            Hi Bob,
                            Steve.
                            Hi Steve i got the part numbers from a post on here somewhere the 2 thrust races i got from Ebay The MS9ACD was ebay and so was the LS10ACD i did google them but a big variation in prices
                            Bob
