Threaded end mills on an ML7
Home Forums General Questions Threaded end mills on an ML7
Viewing 23 posts - 1 through 23 (of 23 total)
  • #220368
    Kit White 1
      @kitwhite1
      I have a 1/2" end mill. They have threaded ends on them like this: Whats the best way without spending hundreds of pounds of holding them in my ML7 Myford lathe's spindle? Can I make a holder out of mt2 stock steel bar with a 1/2unf 20tpi thread on the other end which matches the end mills thread, and just fit that in the spindle?
      Kit White 1
        @kitwhite1
        #220370
        mechman48
          @mechman48
          Can you not get a collet holder to fit your ML7 ?, not that expensive.
          George.
          #220371
            Kit,
            I think the ideal would be to proceed as you suggest, but also slit the Morse Taper, to make it into a collet. [You would, of course also need a draw-bar] … You should be gripping the plain shank, not the thread.
            I have a broadly similar item [in a watchmaker-style] by Crawford Collets, for my BCA.
            Kit White 1
              @kitwhite1
              What type? Should it be mt2 or one that screws onto the spindles external thread?
              #220373
              Anonymous
                Posted by Kit White 1 on 10/01/2016 11:38:15:
                Are you sure the thread is UNF? Threaded endmills are normally 20 tpi Whitworth, irrespective of whether the cutter is imperial or metric.
                #220374
                daveb
                  @daveb17630
                  MT2 collet, available in Imperial and Metric sizes, fits directly into ML7 spindle, will need draw bar or suitable length of studding. Don't bother with the thread, hold the end mill by the plain shank.
                  Edited By daveb on 10/01/2016 12:04:25
                  #220375
                  Kit White 1
                    @kitwhite1
                    Posted by Andrew Johnston on 10/01/2016 11:52:37:
                    No, I'm not sure. It is 20tpi but probably is Whitworth in that case. Thanks.
                    #220383
                      As DaveB says just by a MT collet and make a simple drawbar which only needs to be a length of studding, nut and thick washer. Forget about the screwed shank
                      Edited By JasonB on 10/01/2016 13:17:04
                      #220385
                      martin perman 1
                        @martinperman1
                        I would agree with the above but suggest that the thick washer be shaped like a top hat so that the smaller dia sits snugly inside the spindle to hold the threaded rod centrally to stop any vibration which could undo the nut.
                        Martin P
                        #220401
                        John Haine
                          @johnhaine32865
                          Or grind a small flat on the cylindrical portion of the cutter shank, drill/ream a 1/2" hole in the end of an MT2 blank, and use a set screw to hold the cutter. The thread is not meant to hold the cutter concentric, it normally screws into the Autolock collet to pull it snug – the collet holds the cutter true.
                          #220404
                            Posted by JasonB on 10/01/2016 13:16:44:
                            … a MT collet and make a simple drawbar which only needs to be a length of studding, nut and thick washer. Forget about the screwed shank
                            Definitely easier, and remarkably economical yes
                            … I wonder why Crawfords went to all the trouble of grinding a thread inside dont know
                            Howard Lewis
                              @howardlewis46836
                              If you are tight on space, use a Morse Taper Collet.
                              If you wish to hold other sizes of End Mill, Slotting Drill, or workpiece, my advice would be to buy a holder for ER collet holder, and a set of collets. They will definitely come in handy in the future, for holding tools or round workpieces.
                              #220419
                              daveb
                                @daveb17630
                                Endmills can and often do pull out of plain collets, the main advantage of using them is that the cutter is supported within the spindle so much more rigid, also maximises headroom. A collet CHUCK can extend the cutter 2 or 3" so a bit more bendy and takes up space you may not have on a small machine. The limitation on a ML7 is likely to be the cross slide, it's a bit floppy. If you intend to do much milling on this machine, a Super7 cross slide would be a huge improvement. Drawbar needs to be fairly tight to prevent pull out and keep cuts and feeds light. Dave
                                #220429
                                  Posted by daveb on 10/01/2016 15:56:32:
                                  Endmills can and often do pull out of plain collets, the main advantage of using them is that the cutter is supported within the spindle so much more rigid, also maximises headroom. < etc. >
                                  Thanks, Dave
                                  I must confess that my rhetorical question was slightly sarcastic … The Crawford Collet [which cost me quite a lot, nearly 30 years ago] has proved its worth, on many occasions, for the reasons you mention. My only regret is that I did not also buy the Metric one.
                                  OldMetaller
                                    @oldmetaller
                                    Hi, slightly tangential question- do these MT 2 collets only close on the diameter stated, or do they, like the ER 32 collets I've got, overlap and close on any diameter within their range?
                                    John.
                                    #220540
                                      Posted by OldMetaller on 11/01/2016 10:34:13:
                                      Good question, John
                                      All the ones I have ever used are only slit one way [like Watchmaker's collets] and are therefore strictly 'single size'.
                                      OldMetaller
                                        @oldmetaller
                                        Thanks for that Michael, you've saved me getting my wallet out!
                                        John.
                                        #220852
                                        Nigel McBurney 1
                                          @nigelmcburney1
                                          Hold the end mill in the three jaw chuck,it works,costs nothing,and thats what everyone dud before the various modern collet systems were available,
                                          #220948
                                            Posted by Michael Gilligan on 10/01/2016 14:52:52:
                                            An observation – not much point using the screwed shank unless you have an autolock type collet holder of some sort. Two reasons:
                                            1 if it slips the mill could easily screw itself in so hard it will never come out again.
                                            2 if it is screwed in and slips, it we definitely shift axially (or jam) whereas if it isn't screwed in, it may only spin..
                                            I heart my Osborn
                                            #220964
                                              Posted by Neil Wyatt on 13/01/2016 19:37:49:
                                              An observation – < etc. >
                                              Neil,
                                              I's time to come clean:
                                              The BCA uses 11mm shank collets [Crawford 55 pattern] and that special threaded collet takes 3/8" shank milling cutters. Despite the supeb quality, this leaves a very thin wall on a plain bore. … I believe that at least part of the reason they included the female thread was to 'beef-up' the torsional strength in the area nearest the drawbar thread and the keyway.
                                              I love my Osborn too … but it wouldn't fit the BCA.
                                              Edited By Michael Gilligan on 13/01/2016 21:48:29
                                              #220984
                                              John Stevenson 1
                                                @johnstevenson1
                                                Posted by Nigel McBurney 1 on 13/01/2016 09:26:24:
                                                Is it April the first already ?
                                                #221464
                                                  Posted by Michael Gilligan on 10/01/2016 16:31:27:
                                                  I offer the following solely for the amusement of those who are lucky enough to have purchased acceptable quality ER Collets and Holders at today's bargain prices …
                                                  I have just been sorting some old paperwork, and found the receipt for the aforementioned special Crawford Collet [purchased New, from Tenga Engineering]
                                                  On 11-Feb-1988 : I paid £45.50 +15% VAT
                                                  surprise
                                                  Edited By Michael Gilligan on 17/01/2016 13:45:11
