Thread cutting….what went wrong…?
Home › Forums › Beginners questions › Thread cutting….what went wrong…?
  • #8095
    Paul Relf-Davies
      @paulrelf-davies37806
      #233983
      Paul Relf-Davies
        Good morning.
        I had a little problem thread cutting yesterday. I wanted to cut an M5x0.8 thread on a piece of steel rod, actually a turned down M10 bolt.
        I turned the bolt down to 5.5mm diameter and cut the thread with a tailstock die holder and generous use of cutting fluid.
        On inspection, the bolt had about 3 good threads up close to the shoulder on the bolt ( the last threads cut) and the rest of the piece was completely smooth…?
        It appears that the die cut the threads, then cut them off.
        I was obviously doing something wrong here!
        Any ideas?
        This is the 1st time I’ve cut threads on the lathe (with the die holder) by manually turning the lathe. Previously, I be used power at the slowest pully ratio and in back gears, with no problem at all.
        Cheers
        Paul
        #233984
          Posted by Paul Davies on 10/04/2016 10:54:39:
          Good morning.
          Paul,
          The first question must be : Why 5.5mm ?
          Anonymous
            The second question is: where did the die come from and what does it look like, ie, a picture.
            #233990
              The work should be slightly under size, to allow for metal extruding as the die forms the thread.
              If that isn't a typo and it was a high-tensile bolt, I'm sort of surprised the die has any teeth left on it!
              Ian S C
                @iansc
                Another question, what grade bolt was it?
                To make a 5 mm thread, you use a 5 mm rod, you can go a few thou under size, but why the heck would you go over size?
                Ian S C
                #233992
                Russell Eberhardt
                  @russelleberhardt48058
                  With an oversize starting diameter the cutting force is too great for the first few threads to pull the die along properly.
                  Russell
                  #234012
                  Paul Relf-Davies
                    Oh dear.. I think a moment of dawning illumination has happened….!!
                    When tapping a female thread, one drills the hole under-size…Since I was doing the opposite I turned the rod a little oversize, when (of course!!) I should have turned it to to the final diameter….D'oh blush
                    Shows what can happen when you are in a bit of a hurry!
                    On the plus side….I won't make the same mistake again!
                    TY All!
                    P.
                    #234016
                    Steven Vine
                      @stevenvine79904
                      Been there. As you say, lesson learnt.
                      I've even turned a rod down to tapping size, and confused the hell out of myself.
                      The mind does wander.
                      Steve
                      #234018
                      Ed Duffner
                        @edduffner79357
                        Hi all,
                        I hope Paul doesn't mind me asking some related questions.
                        When cutting single-point internal and external threads on a lathe for parts that will be screwed together, how much tolerance or clearance should there be between the two threads?
                        Should material be removed from both threads or from just one of them to stop them binding and stay on spec?
                        Is the thread 'gap' predetermined by the bore of the internal thread and the minor diameter of the external thread?
                        Ed.
                        #234027
                        John Haine
                          @johnhaine32865
                          Ed, there are two ways to answer this.
                          The first is, go and look at the standards that define the tolerances, if you want to be purist.
                          More practically, it's easier to make an external thread and adjust it to size taking tiny cuts off, so making your own a good approach is to make the internal thread first as close to theoretical size/form as you can, then make the external thread and shave off tiny amounts to just fit the internal thread you just made.
                          It also depends on the purpose of the thread. For fasteners, given that you have a range of acceptable tapping drills for a given thread giving different engagements, you can afford to take a bit more off in the interests of an easy life.
                          #234028
                          Ed Duffner
                            @edduffner79357
                            Thank you John, that makes sense!
                            Ed.
                            #234034
                            MW
                              @mw27036
                              It's okay, i once turned a diameter down to 24.5 as opposed to 25.4 blush
                              Michael W
