Super Adept lathe chuck
Home › Forums › Beginners questions › Super Adept lathe chuck
  • #7399
    Rainbows
      @rainbows
      #172072
      Rainbows
        @rainbows
        New to all this so be gentle
        I got this Super Adept lathe recently but the problem is it didn't come with a big chuck, previous owner only had the sort of chuck that would usually be on a drill and while it does fit on the spindle it doesn't allow for a work piece diameter more than 10mm.
        The lathe has a 3/8" spindle and I am struggling to find any back plates or chucks 1st or 2nd hand on the internet that have the right size.
        How do I obtain a back plate that is the right size for the lathe? Will I have to get one made specially for the lathe?
        #172078
          Hi,
          You will need to get a backplate made, although you might be able to track down an Adept 4-jaw chuck.
          Don't forget, the ideal is to finish the front face of it yourself.
          Might be able to help by making a blank for you, but not quickly…
          Rainbows
            @rainbows
            Might be able to get the use of a friends much larger lathe long enough to machine one so thanks but I don't think it is required.
