Bit of 12mm bar, red lines are the two initial cuts with a 3mm dia cutter having the right one longer gives the tip clearance
But grinding your own should not be too hard or need anything too fancy in the way of grinders of rests.
Take a bit of HSS either bought in or an old cutter and make a simple holder from some square bar so you keep your gingers away from the grinder, don’y have to hold the HSS as it gets hot and to also hold the cutter at a constant angle. Grind a bit of the top down to approx half thickness this can be done freehand on the grinder with uneven wheel
Set the belt sanders rest to tilt down about 10 degrees and then mark two lines at 20deg. with your square holder lined up to one mark by eye grind one side to just short of half way
Do the same for the other line to form the other sid eof your Vee tool
Should look something like this, check the angle and adjust at this stage
Freehand the nose radius by swinging the tool between the two lines with very light contact on the belt
Now to see if it works. this was a bit of 60mm cast iron and the cut 3/32″ deep without the parting gut.
First half of the video I was one handed so had to feed in until it could hear it starting to resonate then moving teh cross slide back and forth a few thou then in a bit more with the cross slide. When the camera angle changes I am working both at the same time with a slow infeed and moving the topslide one way and then the other and it goes in quite quickly.
