I made a test piece for the grooves – much smaller diameter obviously, but the correct width. I wanted to get used to the spacing method, and to try the tools I made.
It wasn’t much of a success – I find grinding tools is hopeless, and the results were – as expected – poor. I think that if it’s not symmetrical, the end grooves to the edge of the wheels would be wrong even if the central groove spacing was correct.
At least I sorted the spacing method using the leadscrew handwheel though.
I reverted to an insert type tool, and things improved a bit, although nowhere near perfect, mainly becasue the workpiece kept moving.
So, what’s the best way of making a VCGT 90 degree holder? Is it a simple case of milling a piece of square bar to get the right height, then drilling for the Torx screw, and perhaps retaining the back end of the tip in a JBWeld “V”? I could coat the tip in grease so that the insert didn’t stick, then I could replace it.
I think that the torx screws in inserts are slightly pre-loaded towards the holder, but I wouldn’t be able to do that I guess.
Not sure If I’d need the 1mm wide parting type tool to start the grooves if I was using inserts? If I did need it, I’ve no idea how I’d make anything other than a mess again – I don’t really have any of the correct equipment for grinding – the wheel I’ve got is worn, and the adjustable jig I made for the boring tools never really worked properly. I’m keen to get on with it, and don’t want to spend hours of trial and error again on trying to make tools that don’t really work.
