Boiler Design – issue 4765
Home Forums Model Engineer & Workshop Boiler Design – issue 4765
Viewing 10 posts - 26 through 35 (of 35 total)
  • #800392
    Andy Stopford
      @andystopford50521
      The Haining designs are useful as an approximate reference, but you can get copies of the original works drawings from The Museum of English Rural Life and rescale and adapt them to your own requirements. They’re not cheap if you need a load of them, but better value to my mind then buying the Haining ones.
      I’m working on a 1/12 scale Z7S, a scale which is somewhat…challenging for such a complicated machine, but its as big as my lathe and indoor workshop allow, and getting the MERL drawings is much better than re-scaling something that’s already been scaled and changed to suit the facilities of the 1980s.
      At this moment my 3d printer is making a mock-up of the coiling gear – I was quite unable to translate Haining’s design into anything workable and I don’t have a works drawing for that (there isn’t a full set for the Z7S) – 21st century technology to the rescue here for something that would be very tiresome to iterate multiple test pieces using old-school methods.
      I’ll probably use the printer to make patterns for some cast bits too(not strictly necessary to use castings for a model of this size, but I have a little propane fired furnace, so why not give it a go – my limited experiments so far have come out far better than some of the commercial Minnie ones I foolishly bought).
      duncan webster 1
        @duncanwebster1
        On Bob Worsley Said:
        Just dug out the emails when boiler kit bought, and contacted Neil Tyler about the changes and never got a reply. Reeves saying it is up to the designer, they just supply what is asked for, Neil Tyler says it is due to the supplier of the kit. So I ended up with £670 worth of scrap copper.
        If you buy anything mail order you can return it for a full refund no questions asked. Thats UK law. There might be a time limit, not sure, ask citizens advice
        #800508
          I have made contact with Alan Brown, one of the authors and invited him to comment. He is a forum member.
          #800509
          Clive Brown 1
            @clivebrown1
            That limit is normally 14 working days after delivery, so this case seems time-expired.
            #800516
            duncan webster 1
              @duncanwebster1
              What diameter and pressure is the BB boiler? The Aus code allows 90 psi for a 5″ diameter 2.5 thick shell. Sorry for the mixed units, peopld of my antiquity had to cope with both
              #800527
                5″ OD x 75psi.
                Though I would want to make an allowance for the fact it is a ploughing engine so quite long and unsupported plus that big winding drum slung below will put loads into the barrel if you pull anything. There are no stiffening pads for the drum bracket, though there are for the cylinder and valve bracket
                I assume that the original 13swg design was found to be a bit wanting and that is why Haining upped it to 10swg (0.126″)
                #800548
                Andy Stopford
                  @andystopford50521
                  Doesn’t Haining also suggest using a steel shell round the boiler to take the loads from the drum and front axle?
                  #800554
                    He does give it as an option in the article but the photos in the article are of a boiler with the brackets soldered direct to the barrel and that is also what is shown on the drawings. Even if you did make it I don’t think you could slide it past the clack valve bushes or fit the smokebox which is still shown to fit the end of the boiler not the steel tube so boiler taking the axle loads
                    #800555
                    duncan webster 1
                      @duncanwebster1
                      There is a separate table for traction engines where the boiler is subject to external loads, thats the figure I quoted. I wouldn’t have thought you’d be doing a lot of ploughing with a 2″ scale model
                      #800561
                        Yes but with a ploughing engine typically having a boiler barrel 50% longer than a traction engine I’d want to see some additional thickness even over the thicker TE table.
                        You have not see Harry Williams pulling loads accross a field with his pair of Kitshons or Ross Bishop running his 3″ under load. generally the models are run with a load rather than an actual plough as rally organizers are not keen to have the grass torn up and it is also hard to find someone smallenough to sit on a 2″ scale balance plough to steer it
                        https://youtu.be/hAcpujv-_4g?si=t8j70PygSsoB_OD2
