Stuart Twin Victoria (Princess Royal) Mill Engine
Home Forums Work In Progress and completed items Stuart Twin Victoria (Princess Royal) Mill Engine
Viewing 9 posts - 1,251 through 1,259 (of 1,259 total)
  • #796494
    Dr_GMJN
      @dr_gmjn
      On JasonB Said:
      Going back to the handwheel suggestion. Put your alignment pin in the flywheel that is in the chuck, slip on the previously turned one and touch the tool on the rim and zero the handwheel. Now you know the setting to turn the second handwheel to.
      It’s times like these that my 300mm digi calliper comes out of the draw.
      Yes, another option. I’d already forgotten about the spigot.
      Dr_GMJN
        @dr_gmjn
        OK, so I’ve used three measuring methods – just out of interest to see the relative accuracies:
        1) A strip of card wrapped around the smaller wheel, and its length (circumference) measured with a tape measure, then wrapped around the larger wheel and the difference measured with verniers:
        IMG_3620
        2) Measuring the chord length and its offest from the circumference using verniers:
        IMG_3622
        3) Height gauge:
        IMG_3626
        Assuming the height gauge is the datum (as the most accurate method) Anyone fancy a bank holiday guess at the maximum and minimum deviation from this – on radius, in terms of thou – between the chord and tape methods?
        I’m going to use Jason’s spigot method as a double-check on the height gauge readings, and hopefully get it done this afternoon.
        Thanks all.
        #796498
          I thought you wanted to do the measuring with the second one still in the lathe, if so height gauge method may be tricky.
          If off the lathe then stand the two side by side and measure the height difference with depth gauge or the back of your callipers.
          But as you have a height gauge then just clamp a flat plate to the bottom and you effectively have a vernier calliper.
          #796500
          Dr_GMJN
            @dr_gmjn
            I did want to keep it on the lathe, but as mentioned I then thought that I really want to bore the hub and face the mating parts of the rim/hub in one setup, to reduce the chance of them being out of true. I’d machined the outer face first (as per the article method I think), which I suppose was a mistake.
            So with both wheels off the lathe, I’ve now just measured them directly with the height gauge, and will take off the measured difference once the second wheel has been re-set.
            I tried the other two methods out of interest to see how accurate (or inaccurate) they would have been.
            #796519
            Dr_GMJN
              @dr_gmjn
              Mounted the second wheel and machined it to the o/d of the first:
              IMG_3627
              Counterbored the hub – I hope this doesn’t interfere with the broching process too much:
              IMG_3631
              Here are the two wheels:
              IMG_3630
              One middle boss is wider than the other, but I suppose this will not be visible once joined and filled. There is still metal-on in terms of overall outer circumference face width, and overall hub length, which I will re-size on the faceplate after joining.
              And fitted to the spigot:
              IMG_3632
              I managed to get both small bores to zero difference according to my gauge and verniers, but unfortunately, despite the spigot being a decent fit in both, I can still wobble the wheels against each other very slightly. I could re-make another shaft to be a tight fit, but am slightly concerned it might lock iteslf in place after clamping the wheels together. I suppose I could make it in brass and that might be easier to drift out?
              Next job is to drill the peripheral holes for the clamping screws, and then do a bit more clean-up of the cast areas before finally bringing them together. Didn’t quite get them joined this holiday, but still some progress.
              By the way, the difference in radius between the card tape, vernier-measured chord, and height gauge (datum) was +/- 0.001″. Maybe it was luck, but I found that pretty incredible especially with the card tape.
              #796520
              Dr_GMJN
                @dr_gmjn
                Thinking out loud again:
                For the final facing operations (after joining), and machining the recess for the barring ring, if I did make a tap-fit brass spigot, turned between centres, could I machine the whole assembly between centres, using a drive dog through the spokes?
                Seems like it would save a lot of setup time, and be more accurate than setting and re-setting on a faceplate for each operation?
                Thanks.
                #796521
                  I’ve never got a good finish doing flywheels mounted like that as the lack of support at the rim causes fine chatter marks Probably won’t be rigid enough for rope grooves either.
                  I prefer to machine the rim OD, one side and do the bore all in one setting which keeps things true then the other side of the rim is a simple facing job.
                  #796525
                  Dr_GMJN
                    @dr_gmjn
                    Yes, I forgot about the most important thing – the bore, which needs opening from about 11mm to 14mm.
                    Re. Bonding the halves, I think JB weld for the hub, and Araldite for the rim – I’m concerned that JB weld on the rim might leave a black line, which, I think in theory would end up on top of the middle peak of the rope grooves. So it would presumably be quite visible. I guess I could JB Weld where the inner spoke blocks are, but from memory it’s quite grainy and might hold the rim apart slightly. Could relieve them a bit, but is it worth the effort?
                    #796541
                      Unless you ar eonly using one of the two tubes your JBW should be grey and quite close to the colour of cast iron. Applied very thinly it should not show anymore than the amber of Araldite.
                      I’d much rather machine across the JBW than Araldite which is always a bit soft even after setting and I’m sure that if Tubal Cain had it available 40yrs ago then he would have used it.
