Stuart beam engine cylinder
Home › Forums › General Questions › Stuart beam engine cylinder
  • #26805
    Eric Cox
      @ericcox50497
      #426327
      Eric Cox
        @ericcox50497
        The cylinder casting for the Stuart beam engine has inlet ports cast into the side (location of the steam chest) and inlet ports on each end of the cylinder. Are these ports connected and if so how do I remove the casting sand that appears to be blocking them.
        #426337
          Bit of fuse wire poked into the holes and banging the casting on the bench will clear the core sand eventually, yes they are connected.
          Edited By JasonB on 28/08/2019 12:58:14
