Posted by Steviegtr on 29/06/2020 02:17:08:
Posted by Martin W on 29/06/2020 00:46:53:
I believe it is illegal to fit LED bulbs into a road vehicle that has main and/or dip lamps that were originally designed for for the tungsten halogen style of light. It is probably related to the fact that the LED structure does not have the same/similar physical location and that this then distorts the beam pattern which could be a hazard to oncoming vehicles especially in inclement weather.
Martin
PS
Here is an article that partially covers the law.
(Edit to add above info)
Edited By Martin W on 29/06/2020 00:55:19
I did look into this before fitting the Philips extreme Led lights. These were very expensive lights & conform with current regs. From memory i paid £132 for them. The problem you raise is that the light defracts & causes glare at the edges of the refractor element. The Philips LED car headlights. Are perfect. I have over the years, spent many hours working on Xenon & LED lights on motorcycles / cars & vans. Most of which were not good for oncoming drivers.
These are great & MOT friendly as my tester who has failed many a vehicle of mine due to this problem has remarked. The beam cutoff point is very good. If you know anything about headlight patterns. You will know how the beam has a cut off & then an angle to match the UK right hand drive code etc. These match. So far i have had them in the Vivaro Sportif for over 2 years without any problems. The light is brilliant. Better than my F-type, which has Bi-Xenon. My motorcycle Multistrada has full LED lights throughout & even turns when cornering. It is a new era.
A snipit . LED lights were illegal in the UK. Suddenly all the new Arriva busses had LED lights. Alla they were no longer illegal.
Steve. My van.
Hi Steve, did you see what it says on eth seller's page:
PLEASE NOTE: These headlight bulbs do not have ECE approval, and as such their usage is currently not approved for use on public roads: their usage is limited to ‘off-road’ applications. In addition, their installation may trigger a bulb error message to appear on the vehicle's on-board computer system / dashboard. This is a harmless side-effect and may be removed by installing a Philips CANbus Control Unit.
