Strimmer /BrushCutter … any recommendations ?
Home Forums The Tea Room Strimmer /BrushCutter … any recommendations ?
Viewing 25 posts - 1 through 25 (of 62 total)
  • #552103
      I am getting weary of struggling with down-market two-stroke engines
      In the last few years I have bought Ryobi/Stihl/Ryobi and they have all failed after a couple of seasons … poor carburettors and weak sparks.
      I don’t really want an electric one, but at least they are reliable !
      Before I succumb : Does anyone have a recommendation ?
      Heaviest usage is clearing brambles from an area of about 100 square metres, in the field beyond our garden.
      Thanks
        Former Member
          @formermember12892
          #552107
          Tony Pratt 1
            @tonypratt1
            I have a Ryobi & it’s been Ok ish for about 15 years, when it lets me down next time I will try a Stihl, they are meant to be the best 🤔 I’m thinking an electric/battery one may not have the guts for brush cutting?
            Tony
            Edited By Tony Pratt 1 on 01/07/2021 16:29:44
            #552112
            Cabinet Enforcer
              @cabinetenforcer
              Struggling to reconcile your description of downmarket with the inclusion of Stihl? Which would be my default recommendation, they have a standard 2 year warranty and currently have an "offer" to extend to 3 years with an additional purchase item.
              My father has a bent shaft "grass trimmer" type which would happily chew through a small area of brambles, I have one of the commercial size machines which is frankly total overkill for my garden, both get plenty of use, the trimmer also abuse, both stihl and both have been very reliable and give off a reasonble air of being properly engineered. The only shortcoming I would describe about either is that I am not too keen of stihl heads, they seem a bit soft/fragile compared to say an oregon one, but they are pretty much a consumable and a standard M14 fitting.
              Edited By Cabinet Enforcer on 01/07/2021 16:41:52
              #552116
              Former Member
                @formermember12892
                #552119
                Robert Butler
                  @robertbutler92161
                  Michael, I am surprised you are suffering from poor carburetors and weak sparks. I have an EFCO Strimmer, Pole Hedgecutter and Blower which I service every January/February along with the mowers. One issue which I have encountered which is a great cause of annoyance is modern fuels which "go off" very quickly and gum up the carburetor and tank. Many years ago I discovered the efficacy of mixing fuel stabilizer with the fuel on the day of purchase. This can be purchased from garden machinery suppliers (rather than the Sheds) and I can confirm fuel will be fine for up to 2 years.
                  The strimmer's and mowers range from 15 – 30 years and as proof of reliable starting I have yet to replace a starter cord – well until I've just added this posting at any rate. They last because of reliable starting.
                  Robert Butler
                  Edited By Robert Butler on 01/07/2021 17:14:17
                  Edited By Robert Butler on 01/07/2021 17:15:08
                  #552121
                  Tony Pratt 1
                    @tonypratt1
                    Yes modern petrol is a right PITA as far as rotavators & strimmers are concerned.
                    Tony
                    #552122
                    Robert Butler
                      @robertbutler92161
                      Not if you use fuel stabilizer
                      Robert Butler
                      #552123
                      Former Member
                        @formermember12892
                        #552125
                        Robert Butler
                          @robertbutler92161
                          Dear Bill, yes used it for many years. I can't be doing with things that don't work. Makes you wonder what I saw in Er in Doors! In fact she's the only thing in the house that doesn't work!
                          Robert
                          Edited By Robert Butler on 01/07/2021 17:25:41
                          #552126
                          Bo’sun
                            @bosun58570
                            Hi Michael,
                            Here's my two pennyworth. I would have a look at ECHO products and "Aspen 2" 2 stroke alkylate fuel. It's ready mixed, ethanol free, has a long shelf life and it's better for the operator. Warning though, Aspen 2 isn't cheap.
                            I'd look for a model with a gearbox and a straight shaft, rather than the bent shaft variety.
                            If you want to do bramble bashing with a mulching/shredding blade, make sure the brush cutter warranty will be OK with it.
                            #552131
                            duncan webster 1
                              @duncanwebster1
                              I've got a Bosch electric, biggest heap of junk I've ever bought
                              #552138
                              noel shelley
                                @noelshelley55608
                                Try TANAKA, not cheap, a contractors machine, uses 3mm square cord. If the starter is on the left of the engine I would not buy, it's an overhung crank. Starter must be on the Right. Correct fuel mix is vital and new , not last years. ! Good luck, Noel
                                #552140
                                Nicholas Farr
                                  @nicholasfarr14254
                                  Hi, I've got one of these Titan TT530GBC and is the best one I've had, but the only problem it's had, is the air filter and clip on cover doesn't stay on, but it's been working without it for at least three years.
                                  Regards Nick.
                                  #552145
                                  MichaelR
                                    @michaelr
                                    I have a Honda Strimmer Brush Cutter a 4 Stroke OHV never missed a beat had one new plug in 5years I change the oil regularly not cheap but worth the price.
                                    Mike.
                                    #552146
                                    old mart
                                      @oldmart
                                      For a strimmer, be sure to get one that advances the line/s automatically when you tap the head on the ground. I ditched the posh one and went back to Black & Decker because of this .
                                      #552156
                                      not done it yet
                                        @notdoneityet
                                        I’m in agreement with MichealR. Bought one new – really expensive compared to the two strokes – and has given no trouble at all. Not over-worked but just keeps going. In fact, I bought another – a second hand one at an auction – because I fancied the twin handled type to compare with the ‘hoop’ type. I now tend to leave the (expensive) chain saw attachment on one and the strimmer/brush cutter head on the other. Now over-kill, ‘cos we gave up the 3000m^2 patch (we rented) last year.
                                        I bought a large reel of square nylon strim which lasts well but needs winding on carefully for auto feeding.
                                        Both are straight shaft machines – I would not entertain a bent shaft machine. I have two-stroke machines – cheaper generators and pumps, post hole borer and the Mantis cultivator (a good machine, but I wish I had bought a 4 stroke variant). Messing about with two stroke oil is a pain. Apart from the power to weight ratio, I prefer 4 stroke engines any, and every, day of the week.
                                        Edited By not done it yet on 01/07/2021 19:27:29
                                        #552157
                                        Meunier
                                          @meunier
                                          +1 for Echo products. Have a brushcutter with Oregon head and alligator blades. Works well with Handlebars, starts 1st time every time (de-compressor button ) Invested 49GBP in a Husquvarna body harness, no more bruised hips or sore shoulders. Also Echo 22ins chain-saw, just as dependable.
                                          DaveD
                                          #552161
                                            Thanks for all the comments so far yes
                                            I will just respond briefly on three points for now:
                                            • I was assuming that an electric machine would need to be mains [or preferably 110V for safety] to get enough power and duration … I may, of course be wrong.
                                            • I bought the Stihl, together with a small chainsaw, on ‘brand reputation’ … the saw is quite good, but the strimmer was mediocre at best. I believe only the top end of their range merits the reputation.
                                            • Robert says “The strimmer's and mowers range from 15 – 30 years” … and I think that may be my problem [they don’t make ‘em like they used-to]
                                            I look forward to any more advice … I may still have a few weeks before the brambles take over !!
                                            pgk pgk
                                              @pgkpgk17461
                                              I use a big Husqvarna strimmer with handlebars and a harness and I have a lot of edges, ditch edges and stuff to do with it
                                              It was old when i bought it with this farm 10years ago and still starts easily and I’m pretty sloppy about leaving the end of season fuel in it over winter etc.
                                              But it is heavy and a rare day i can use it through a full tank..
                                              If your brambles are on a flat then I’d barge through them with a small front deck ride on but steep and inaccessible means manual or spray it.
                                              Biggest issue with the husky is if I run it full chat – tends to snap strimmer line a lot more often than slower speeds and I’ve got the heaviest stuff you can shove in it.
                                              Re cordless garden stuff; I've a lidl hedge trimmer and whilst it runs slower than a 2-stroke the quality of the cutter blades is superb 30yards of privet top and both sides and 1/2 the battery pack still usable. On the other hand i have a battery pole saw with skip chain that’s pants compared to my Stihl – but then the Stihl is a muscle mans machine on full height. so the battery job gets used for one-off and small branches
                                              pgk
                                              Edited By pgk pgk on 01/07/2021 20:17:05
                                              #552163
                                                Regarding the carburettors …
                                                This is not the exact model on my Ryobi [mine is even nastier] … but the fact that an overhaul kit is not available does seem indicative of the market sector: **LINK**
                                                How to Clean a Two-Cycle/Two-Stroke Engine Carburetor: https://youtu.be/Z18WwhxEtxI
                                                  Posted by pgk pgk on 01/07/2021 20:10:04:
                                                  The brambles are on someone else’s property, on a slope, just over my fence-line … Using a manual strimmer on a small area is probably all I can get away with.
                                                  Clive Foster
                                                    @clivefoster55965
                                                    No idea about brush cutting abilities but I'm very impressed by the capabilities of the twin 18 volt ie 36 volt battery Makita strimmer.
                                                    As, or maybe a little more, capable than the petrol Roybi I had before dipping my toe into the battery side of things with a 36 volt Bosch after decided it wasn't worth putting up with petrol engine noise for the amount I have to do although my garden is plenty big enough to make cable handling with the mains electric ones a chore. Which was where the Royboi came in.
                                                    The Makita is more powerful than the Bosch was but the Bosch "feed on restart" line handling system beats the Makita "beat it on the ground to release the lock" system hands down.
                                                    I initially moved into battery electric by getting 36 V Bosch strimmer and hedge cutter. After being impressed by a Makita 18 volt LXT drill & impact driver set gotten when my NiCAD batterries died I've been working my way through transitioning everything to 18V LXT Makita so the Bosch kit went so I only had one breed of battery to look after, The extra performance being a bonus.
                                                    #552171
                                                    peak4
                                                      @peak4
                                                      When we bought the new house over in Buxton, I picked up a second hand Makita DBC260L
                                                      http://mowerexpress.co.uk/acatalog/Makita-DBC260L-Petrol-Brushcutter-with-Straight-Shaft-MEMK759.html
                                                      The previous owner was a gardening business, and he was selling to upgrade to a much larger full harness machine. It looks like it's been well used and is still going strong; carbs etc are available.
                                                      I have only used it as a nylon wire machine, though according to the above link it takes a chainsaw attachment amongst others.
                                                      Going to this link, it suggests that they only sell them for a different (out of stock) model though.
                                                      http://mowerexpress.co.uk/acatalog/Makita-Brushcutters.html
                                                      Bill
                                                      Edited By peak4 on 01/07/2021 21:22:25
