Ian I tend to work small parts on the end of a bar so can often have 18" or so of bar sticking out the end of a block if say machining a square on the end. Each time the block is reset in the vice for the next face you have to ensure it is up tight against a vice stop and knocked down firm which is not easy with a long length of bar making the block unbalanced. With the indexer all I do is undo spindle lock, index to next position, lock spindle , cut and repeat. Its not that the blocks are inaccurate but that you have to spend time making sure you accurately reposition them.
Piston can't be done in a Stevo indexer as they don't stand on end for the first op.
One other thing is what do you do if you are holding say a 10mm dia part in your ER block and want to hold a 10mm cutter in your ER collet chuck to machine it? Not a problem if holding work in a 5C collet
J
Edited By JasonB on 08/01/2016 17:21:48
