Steel spec
Steel spec
Home Forums General Questions Steel spec
  • #198525
    duncan webster 1
      @duncanwebster1
      Can one of the suppliers out there explain why they are so reluctant to tell us what grade of steel they are selling? I've just bought some described as GCQ, which seems to mean 'good commercial quality'. I asked a proper steel stockholder, and he reckoned it meant 'I've lost the certificate'. Presumably model engineering suppliers buy in quantity from stockholders, and in my experience a reputable stockholder will always give you a certificate, most of them whether you want it or not, it's part of their QA procedures.
      duncan webster 1
        @duncanwebster1
        #198528
          In the last year or so I have used M-machine, College Engineering, my local stockholder and Metals Supermarket, all of whom have been able to give me graded materials. I know Noggin End also supply to spec. The hobby-specific stockholders are particularly good for small quantities and specialist materials.
          All of these are specialist metals suppliers.
          John Rudd
            @johnrudd16576
            Posted by duncan webster on 30/07/2015 20:39:47: a reputable stockholder will always give you a certificate, most of them whether you want it or not, it's part of their QA procedures.
            And so they should, as part of their ISO creditation
            #198545
            John Stevenson 1
              @johnstevenson1
              Posted by John Rudd on 30/07/2015 21:17:36:
              No.
              Imagine just how many tonnes of material they shift per day and it's not a full load to one customer. Now imagine if they had to supply paperwork to 90% of customers who are more interested in delivery and price and bot some spurious BS number that have no idea what it means.
              OK there will be some customers who need this certification but the supplier I use if you want certs you pay for them. It's not a free service.
              Most of my stuff is GCQ which usually is EN3B. If I want EN8 I get EN8 and it colour coded. If I need a cert I have to tell them at time of ordering and it's issued. It has to be like this as not only is the bar certified but where it comes from, where it was stored in the warehouse, who picked it, who delivered it is all on there.
              I have to pay for the cert but I expect this – no one – only model engineers work for nothing.
              #198556
              Bill Pudney
                @billpudney37759
                The cert. also used to specify when and where the material was made, the melt that it was part of and the chemical analysis. THAT's why there is a cost involved.
                cheers
                Bill
                #198575
                Mark C
                  @markc
                  Amazing! The QA people will soon be in our tiny workshops were the HSE failed…….
                  Mark
                  #198581
                  John Stevenson 1
                    @johnstevenson1
                    Posted by Mark C on 31/07/2015 09:58:53:
                    Mark
                    No really, it's only people worrying over something that is not necessary.
                    In a year I buy literally tonnes of steel in, OK low tonnes but still a lot for a shop my size. I hardly ever buy in cut lengths unless of a high grade and size. A 4" bar of EN24T does get quite expensive.
                    The biggest majority is GCQ and some higher grades like EN8, EN16T, EN24T and the occasional lump of EN39
                    None of it comes with a test cert, it's colour coded, I mark it up as well and it's stored away from the GCQ.
                    Seeing as nothing I do is life critical and needs a trace, why do I need a cert and if I don't working at a higher level than the home shop guy, then why do they ?
                    Answer is , they don't. Nothing to see here, move on.
                    #198584
                    richardandtracy
                      @richardandtracy
                      The company I work for makes boxes, mostly aluminium, but there are about 20 off 5 tonne net boxes a year are from steel. Stockists are so careless about grades that we now refuse to take it off the truck unless the CofC and mill certs are in order – this leads to 50% of trucks being sent back with the steel still loaded on the back. We have had occasions in the past when we made boxes to go to cold areas requiring -20C capable steel, and got the paperwork after making the box – finding it was stuff that was of a lower strength grade and went brittle at 0C. Fur flew then, I can tell you.
                      Richard.
                      #198605
                      Mark C
                        @markc
                        Richard, John is right about hobby shop use.
                        The circumstance for your company (also John and I) is different to your average model engineer who just needs something that will machine or weld OK. For ISO QA companies and for CE cert. you do need to have traceability (especially if it is automotive) but again John is bang on about having to pay for them – I recently had some sheet material that was rolled CR4 and they gave me the copy of the CofC (certificate of conformity – the thickness specification/tolerance) but I had to pay for a material certificate at an independent test house.
                        I would suggest that you have to be careful with colour codes as (and I stand to be corrected here) they do not have to use a standard coding system.
                        Mark
                        #198647
                        duncan webster 1
                          @duncanwebster1
                          I'm not asking for a copy of the cert, just tell me in the advert is it EN1, EN1a En3 etc. This costs nothing. GCQ is meaningless.
                          #198650
                            Posted by duncan webster on 31/07/2015 19:52:20:
                            They probably don't know … and almost certainly couldn't prove it.
                            GCQ is a very appropriate "downgrade" for the unknown.
                            Simple fact: Traceability and Certification cost money.
                              As does advertising space, so you can't expect them to put too much on the page. If you want something specific then ask them.
                              #198655
                              John Stevenson 1
                                @johnstevenson1
                                Did LBSC ever suffer from such trivia ??
                                #198657
                                Frances IoM
                                  @francesiom58905
                                  “I would suggest that you have to be careful with colour codes as (and I stand to be corrected here) they do not have to use a standard coding system.”
                                  my local metal supplier was kind enough to print out a chart of their own colour code (often over painted on the suppliers own code I presume for the same reason of different standards) – very useful for many of the small endpieces I’m allowed to scavenge from the waste bins are painted
                                  #198783
                                  richardandtracy
                                    @richardandtracy
                                    Posted by John Stevenson on 31/07/2015 20:27:29:
                                    Probably not. But he did live in a time when Esperanto was invented on the spot and the bureaucrat did not rule the earth.
                                    Richard
                                    #198790
                                      Posted by Frances IoM on 31/07/2015 20:42:58:
                                      "I would suggest that you have to be careful with colour codes as (and I stand to be corrected here) they do not have to use a standard coding system."
                                      my local metal supplier was kind enough to print out a chart of their own colour code (often over painted on the suppliers own code I presume for the same reason of different standards) – very useful for many of the small endpieces I'm allowed to scavenge from the waste bins are painted
                                      I've been caught that way. "I want a bit of that" (points at painted offcut) "If you want a bit of that you don't want hat you want this!"
