I would not want to be without my variable speed now. Its ideal when cutting threads using a die on the lathe, I can turn down a bit of hex to the required size at say 1000rpm then just back out the tool, bring up the tailstock, turn the speed down to 50rpm at the same time then run the thread down the part before running in reverse to back the die off at a faster speed then back upto 1000rpm to tidy the end with a file. Far easier than stopping the lathe, fitting a spindle crank, winding that to cut thread and then back it out.
Likewise when drilling a hole in stages, start with a small drill at full speed then just keep changing bits as you work up through the sizes to a big blacksmiths drill no need to keep stopping and moving gear levers or worse change belts.
Same with the mill its nice to slow it down for countersinking, running an out of balance boring head or using the dial type centering gauge without the needle being a blur. I would have thought a VFD on your Sixis with its 1000rpm slowest speed belt was ideal if you want to use it with anything else than small milling cutters.
Used sensibly with the lathe belts/gears set for the main work in hand and the VFD to drop it down on occasion makes things very nice to use.
I think most stories of low torque are from the imported machines that use DC motors on variable speed rather then VFDs on AC motors
J
Edited By JasonB on 15/05/2014 13:35:59
