I don’t see a problem in procuring sulphuric acid if you are a legitimate user. Tighter precautions (due to abuse by the dregs of society) should not prevent the proper and legitimate use of chemicals such as this.
Thirty years ago I used concentrated acids (mainly nitric and hydrochloric), concentrated caustic soda and several other potentially offensive chemicals by the 50l carboy or 50kg bag. Never ever considered abusing those chemicals, but there are those that will do so. A bit like the demise of ammonium nitrate as fertiliser….
Requesting a suitable dilution, rather than just ordering concentrated acid, may be a better way to realise an order without the initial point blank refusal. Discussing your needs with the company, beforehand, is also far better than trying to change their attitude later. Using bisulphite may be a cheaper process, even if slightly slower.
Expect some checks on your disposal methods, these days, mind!
As an aside, salts can range from strongly acidic to strongly basic, with all values between. Bisulphite – acidic, sodium chloride – neutral, washing soda – basic. The pH of an aqueous solution depends on the radicles in solution and their concentration. Simple basic chemistry.
