Skilled hobbyist lathe turners help required
Home Forums Beginners questions Skilled hobbyist lathe turners help required
  • #85084
    Mick Miller
      @mickmiller51111
      Good day ladies and gentlemen,
      This is my first post and I'll put my hands up and say I'm not a model engineer nor have any knowledge of the world of model engineering, but I figure this may be the best place to put in a request for a bit of custom hobbyist lathe turning work for hire.
      I require a small adapter making to fit between a Cobra/ Merlin Day Scope Adapter and my NS200 Nite-Site Camera (don't worry, none of this will mean anything to you but all will become clear).
      Ideally made acetal homopolymer (Delrin), nylon or similar. I only need one for now. Please bear in mind that the tolerances are added but I have no idea what is an acceptable tolerance for a turner. .2mm is probably good enough for me as I can fine tune the fit with emery.
      Not sure whether this would interest anyone here, what it would cost to produce or anything else but please let me know if any of you are interested. If it helps, I'm in Hertfordshire/ Essex so could drive over to discuss what I need in greater detail if any of you are close?
      Apologies if this seems like a completely random request!
      #5963
      Mick Miller
        @mickmiller51111
        #85096
        JOHN KNIGHT
          @johnknight56112
          may be able to help, sent you a personal message
          #85099
          Mick Miller
            @mickmiller51111
            Thanks for your replies folks, I have this sorted now.
            Regards to all those that offered help.
