Single pointing a thread
Home › Forums › Beginners questions › Single pointing a thread
  • #8106
    frank brown
      @frankbrown22225
      #235157
      frank brown
        @frankbrown22225
        I am ploughing on making a metric collet. It. The thread on it is 14.45 mm max diam with a 1.2 mm pitch.When I view the thread through a microscope it has a 55 degrees with rounded troughs and peaks like a Whitworth.
        So eventually I will make a tool that cuts the correct trough shape and angle, the question is how do I get the peaks rounded and at the correct diameter. If I just use an OD of 14.45mm when the thread is the correct minor diameter, the peaks will have "flats"on them so they will need rounding off.
        Any ideas on a (cheap) way to go?
        Frank
        #235164
        pgk pgk
          @pgkpgk17461
          Why? Does it matter if the peaks are flat..or only slghtly rounded with scotchbrite?
          #235184
          Muzzer
            @muzzer
            #235194
            chris stephens
              @chrisstephens63393
              Hi Muzzer, all very good but he said it was Whitworth form not metric.
              #235197
              Phil P
                @philp
                Frank
                Your thread angle is actually a Lownherz standard with an included angle of 53° 8'
                I have based that on guessing you are making a Lorch type B collet for your Alexander/Deckel high speed milling head.
                I have an original drawing of these collets, if you want a copy PM me.
                Phil
                Edited By Phil P on 18/04/2016 22:34:00
                #235218
                frank brown
                  @frankbrown22225
                  Many Thanks Phil, you jogged my memory, I think it was you who sent me the drawing about three years ago (Crawford Lorch collet). Interestingly the thread form is shown with flat peaks and troughs which on all of mine, as said are nicely(?) rounded. It does simplify cutting the threads, just have to do a bit of maths to calculate the actual dimensions, as opposed to the measured ones.
                  Frank
