Sieg C6, Grizzly G0516, Hare & Forbes AL-60 Metal Lathe Modifications
Home Forums Manual machine tools Sieg C6, Grizzly G0516, Hare & Forbes AL-60 Metal Lathe Modifications
  • #414154
    Blue Heeler
      @blueheeler
      Known as the Sieg C6 or the Grizzly G0516 or the Hare & Forbes AL-60 metal lathe. A look at some of the mods that I have done on this 10×22 lathe.
      Edited By Blue Heeler on 14/06/2019 07:13:27
      Blue Heeler
        @blueheeler
        #414167
        Perko7
          @perko7
          Hi Blue Heeler, I also have a Sieg C6, about 3 years old now, very happy with it so far. Could you tell me how you made your carriage lock please as that is something I would like to add to mine.
          Thanks.
          #414186
          ega
            @ega
            Ingenious use of cheap ratchet spanner to lock and unlock tailstock!
            #414194
            Ron Laden
              @ronladen17547
              Excellent Blue,
              Simple, uncomplicated, low cost mods which have made the lathe much more user friendly, great stuff.
              Ron
              #414318
              Blue Heeler
                @blueheeler
                Posted by Perko7 on 14/06/2019 09:27:51:
                Thanks.
                I turned up the steel part that you can see and used a button die to thread it (sorry off the top of my head I can't remember what size metric thread it was) then screwed it in where the factory hex head bolt is. Tightened it up with some vice grip pliers protecting the steel with some offcut copper sheet.
                When it locked down the carriage I marked the place with a small punch where it was the place to drill for the handle.
                Then unscrewed the piece and drilled it for the handle, wound the steel part back in and THEN put the handle in. This way you'll have it set just right so when you lock the carriage it will be in correct place.
                You'll never look back at using the old hex method again!
                #414319
                Blue Heeler
                  @blueheeler
                  Posted by ega on 14/06/2019 11:07:32:
                  That was so simple and its been so effective!
                  #414320
                  Blue Heeler
                    @blueheeler
                    Posted by Ron Laden on 14/06/2019 12:46:05:
                    Excellent Blue,
                    Ron
                    Cheers Ron, and the best part, if I can do these…..anyone can!
                    Thanks
                    Jim
                    #414355
                    Perko7
                      @perko7
                      Excellent, thanks for that.yes
                      #414455
                      Blue Heeler
                        @blueheeler
                        You're welcome.
                        Cheers
                        Jim
                        #415566
                        Vic
                          @vic
                          Yes, I’ve been using one of those on my lathe for years. I’ve seen many mods to convert these tailstocks to lever lock but I can’t be bothered! smiley
