I see… the saddle is kept in place by two strips fixed to the inner edges of the shears. So it's the same as other mini-type lathes, just 'inside out'.
No-one explains how to adjust these -the grub screws are used in opposition to the fixing screws to set the position and no shims are needed.
Take care not to overtighten the fixing screws or you will distort the strips and wear the bed.
Smooth movement is the objective, not the absolute elimination of any movement.
