Short morse taper drill bits.
Home › Forums › Workshop Tools and Tooling › Short morse taper drill bits.
  • #234626
    Mark P.
      @markp
      Does anyone know if short (1/2 length)MT2 drill bits are available?
      Regards Mark P.
      #18059
      Mark P.
        @markp
        #234635
        John Stevenson 1
          @johnstevenson1
          Certainly. When they are half worn out………………
          #234650
          HOWARDT
            @howardt
            We used to use split morse taper holders with tangled drill of the required length. Expensive as tang sizes change as drill sizes increase so require a number of sleeves. Cheaper to use collet holder or simple chuck.
            #234664
            Chris Evans 6
              @chrisevans6
              I tend to use a cut off wheel and shorten well used ones. It is usually the first couple of inches of flute that is worn.
              If I am only "rough" drilling I will sometimes grind the drill a bit one sided to cut slightly over when the flutes are showing wear, tends to stop the rubbing.
              #234668
              Mark P.
                @markp
                Thanks chaps might go looking for old ones at autojumbles etc and cut them down.
                Mark P.
