Security bit identification and how to get it out
Home Forums General Questions Security bit identification and how to get it out
  • #363311
    Rainbows
      @rainbows
      Fished a bike out of a local pond using a piece of steel tied to a rope but since wheeling it back to my garage to restore it I found some odd ball fastners.
      First is some Penta Plus sockets holding the pedals in
      The second pair, holding the handle bars and seat on I don't even recognise.
      Anyone recognise this bad boy?
      Awful quality photos but my camera cant seem to differentiate the different shades of black too well.
      Second part of the question is how do I get them out? A penta plus driver would be fairly easy to make if I had a dividing head but alas don't have one of them. Im not even sure how the geometry on the 3 spoke one works. A triwing driver didn't get deep enough in. Thinking off drilling them out but I feel the geometry would chowder up and drill bit. Any ideas?
      Rainbows
        @rainbows
        #363313
          Odd to have security fixings on a bike, are you sure it's not a stolen/dumped "Boris bike" or similar?
          #363314
          peak4
            @peak4
            Could it be a different size TriWing driver? Like these
            What make of bike is it?
            Not sure what lathe you have, other than a Pultra or similar, but are the bull wheel teeth divisible by 5, in which case a detent on there would do for indexing. If you've a large enough mill, you could even mount a miny lathe, or its headstock, on that and use as a dividing/indexing head.
            Bill
            Edited By peak4 on 22/07/2018 10:29:58
            #363315
            pgk pgk
              @pgkpgk17461
              If you have a mill then the penta driver should be possible without a dividing head – just some round stock and cut the first flat by calculated depth and then rotate using a simple template of the angle against an engineers square? That should get you the plug shape and I'd reckon a good chance you could anneal and hammer some tube around that for the socket shape.
              You mght be able to use a similar technique to make the second driver too with the stock vertical and PCD to plunge-cut the three radii for a template to hammer a socket to shape? If you don't have a cutter the right diameter then fly cut it down or use a boring head.
              pgk
              #363321
              Vic
                @vic
                Posted by JasonB on 22/07/2018 10:04:34:
                Odd to have security fixings on a bike.
                Yes agreed. I suppose cycle shops will have the drivers for these?
                It’s bad enough that M7 is a standard cycle thread. smiley
                #363324
                Gordon W
                  @gordonw
                  I've just acquired a bike- all sorts of threads and heads. I suspect the head types are more for looks than security, as in "wow, it's got security bolts, must be expensive ". Also there are many different makers of the bits and all have their own ideas. Does not solve the problem tho'. I have a couple of assortment packs which do most ,but not the penta-lobe. Will get them when needed.
                  #363327
                  Ian S C
                    @iansc
                    The bike makers like selling expensive tools. The first one I'd take the Dremmel, and either cut a screw driver slot across the screw head, or do as I did for Robinson screws and modify an old Philips screw driver(in that case square), it's not too hard to eye ball a pentagon.
                    Can't help with the other one.
                    Ian S C
                    #363359
                    Bazyle
                      @bazyle
                      triwing? or tri-wing
                      avoids paying royalties to Posidrive and Philips I suppose
                      Edited By Bazyle on 22/07/2018 14:44:30
                      #363367
                        Posted by Bazyle on 22/07/2018 14:42:15:
                        Bits are readily available, either individually or within sets like this: **LINK**
                        https://www.toolstation.com/shop/p52910
                        Muzzer
                          @muzzer
                          That triwing thing is just gagging to be shown a sharpened masonary drill. You might almost say the same about the pentagonal one. Might be a bit of a sod to loosen if it's been in a pond for a while, so not convinced I'd try to make anything to fit.
                          There's also the TIG approach which comes with the benefit of applied heat….
                          Murray
                          #363382
                            What photos?
                            I see nothing relevant in your albums…
                            Ah they are there now, page must have loaded incorrectly.
                            As Jason says, you aren't 'receiving' are you?
                            Edited By Neil Wyatt on 22/07/2018 18:11:31
                            #363395
                            David Standing 1
                              @davidstanding1
                              Nobody would want to 'restore' a Boris bike, unless they 'restored' it back to the pond it was dragged out of wink 2
                              #363396
                              Alan Johnson 7
                                @alanjohnson7
                                Dremel, angle grinder, oxy-acet spring to mind as suitable "spanners!"
                                #363403
                                Jon Lawes
                                  @jonlawes51698
                                  Only place I've ever seen Tri-wing is a BAE Hawk! Tri wing I thought look a bit narrower on the "wings" than that.
                                  #363405
                                    This is probably the most comprehensive and convenient reference list I have seen: **LINK**
                                    http://www.fastenerdata.co.uk/screw-driver
                                    Meunier
                                      @meunier
                                      Posted by Michael Gilligan on 22/07/2018 20:53:36:
                                      Thank you for that MichaelG, an interesting run-down.
                                      DaveD
                                      #363461
                                      simondavies3
                                        @simondavies3
                                        Posted by Meunier on 22/07/2018 21:24:21:
                                        DaveD
                                        +1
                                        Simon
                                        #363477
                                        Vic
                                          @vic
                                          Wiki has the best listing of screw types that I’ve seen:
                                          I’ve seen most types at one time or another but not the Bristol.
