Rubber hose
Rubber hose
Home › Forums › General Questions › Rubber hose
  • #262723
    steamdave
      @steamdave
      I'm looking for some wound rubber hose either 1/8" or 4mm bore. The sort of thing would be like the hose used on loco brake pipes, but I can't find it in the catalogues I've looked at.
      About 18inches total length needed. Does anyone know of a supplier?
      The Emerald Isle
      #24823
      steamdave
        @steamdave
        #262727
          Not seen it that small Dave. You may have to resort to winding wire around a plain hose and then covering with heat shrink insulation.
          #262731
          not done it yet
            @notdoneityet
            A length of bicycle valve rubber?
            #262737
            steamdave
              @steamdave
              JB. Your idea is ok, if I can find thin enough rubber to start with. Don't want it too bulky!
              NDIY. Can you get bicycle valve rubber in long lengths (2 x 9" or 4 x 4-1/2" – ish)? If so, that might be better than JB's idea.
              The Emerald Isle
              #262738
              Roger Provins 2
                @rogerprovins2
                Try Demon Tweeks http://tinyurl.com/h2rktp3
                Roger
                #262749
                steamdave
                  @steamdave
                  Found some. From our favourite on line auction establishment: 190885058500. Shoulda looked there in the first place!
                  Thanks for the various suggestions.
                  The Emerald Isle
                  #262763
                    But that is smooth hose, I thought you were after something that looked like the old reinforced hose. Could have pointed to to smooth straight away
