I have one of Warco's HV4 Rotary Tables which has not been greatly used in the 7+ years I have owned it. However, I want to use the table on an item about 2.5" diameter, held in a mandrel in an ER32 collect chuck. The collet chuck is screwed onto a fitting with a M2 Morse taper into the rotary table. The fitting was turned true in the lathe having been secured to a M2 blank end arbor fitted in a M2 to parallel adaptor and set up to run true, so I was sure this item was good.
Out of interest, having set up the part on the mandrel in the collet chuck on the table I clocked the part which I had just turned true with a DTI. It showed about 0.010" run out of true over the 360 degrees. Checking why, I put a brand new M2 blank end arbor from Arc with a 1.5" diameter end – this I reasoned should – must – run true, it didn't.
Then I found that although I had put the new arbor in the RT M2 taper securely (I thought!) there was slight movement on the top. 'Bluing' the new taper and trying it in the 'hole' showed that it fitted well at the bottom but was not touching at the top. I then tried it in a M2 to 1" parallel adaptor – perfect fit.
So the conclusion is that the M2 hole in the RT is not true and required remedial action.
My thought was to run a M2 reamer down the hole, but wondered if this would work, would the hole be too hard for the reamer, would the reamer ream true or at an angle?
I thought that if I centred the RT under the quill I could hold the reamer in the quill and gentle do it, which would hopefully make it ream true, but would the material being reamed be too hard?
Anyone been down this route? Any advice or thoughts other than using a reamer?
Chris
