Posted by Michael Gilligan on 04/03/2017 13:55:37:
Posted by John Stevenson on 04/03/2017 13:38:43:
Micheal, what good will seeing a certificate give you after you have already said it's not worth the paper it;s written on ?
John,
The certificate is evidence for, or against, my 'case' …
Larry mentioned a certificate, but did not tell us what it certified. … It is plausible ['though unlikely] that the certificate is so worded that Larry's table is within spec.
We all have our niche areas of interest; and one of mine is Probity.
Maurice,
May I refer you back to my earlier comments ^^^
'Merchantable Quality' 'Fitness for purpose' and such concepts are much more meaningful in the context of an item which is purchased on the basis of a specification. … I have little doubt that Larry's table could be described as "a rotary table", and therefore, unless the concentricity of the taper was specified [and/or its intended purpose described] the case would be difficult to prosecute. Chester, or the Manufacturer, might simply say that the taper was provided for convenient rough-location, and not intended as a register.
Yes, of course, it is very convenient to have the bore concentric with the axis of rotation … but …
P.S. [just for clarity] John slightly mis-quoted me: What I originally wrote included the word "probably":
"… as for the Certificate
it's probably not worth the paper it's written on; but I would be interested to see a copy."
Edited By Michael Gilligan on 19/03/2017 08:49:57
