Rob Roy loco
Rob Roy loco
Home › Forums › Beginners questions › Rob Roy loco
  • #174996
    Ian Horsfield 1
      @ianhorsfield1
      Many of you who have made Rob Roy will have encountered the problem I now have.-Can you help me?
      I have made the steamchests 11/16 thick with the height for the valve spindle 7/16 as orig sht2 drg. The general assembly of the slide valve and cylinder shows this 7/16 dimension but it is drawn at 5/16!!!!. I have also made the slide valves 1/2 thick and upon assembly the bottom face of the slide valve is 1/8 away from the port face of the cylinder. Should I reduce the thickness of the steam chest by 1/8?
      Looking at the book I now see that the slide valve nut has grown from 1/4 to 3/8 and the height of the valve spindle hole to .240. (Should this be .250?)
      If I make new slide valve nuts that will give me the 1/8 I need. What do you think?
      Any help would be appreciated before I make more swarf.
      Thanks
      -Ian
      #7430
      Ian Horsfield 1
        @ianhorsfield1
        Help with drawing errors? – Steamchest and slide valve thicknesses
        #175001
        Steve F
          @stevef
          Hi
          I remembered seeing this here **LINK**
          I hope this helps
          regards
          Steve
