I have a Myford Super 7B lathe and I am VERY distressed to have broken a tooth from the 39 tooth Tumbler gear in the Norton QC gearbox. (Don't ask it is too painful)!
At the end of a turning job that was on the limit of the Myford's capacity, there was a thump and it was found that a tooth had broken from the Tumbler gear.
The attached photo illustrates the problem of trying to remove the tumbler gear in order to replace with a new gear. The replacement gear wheel is apparently available from Myford, but I cannot see how they could have assembled it in the first place, nor can I dismantle it.
The photo shows the Input shaft of the gearbox withdrawn from the Input shaft housing in order to show the spline on the input shaft which normally runs in the input shaft housing. The Tumbler gear normally protrudes through a slot in the input shaft housing to engage with the spline in the input shaft.
The selector, which is a casting, slides on the input shaft housing to enable the tumbler gear to engage with one of the nine gears for the various ratios. The bottom of the selector caries a short spindle on which the tumbler gear runs and the short spindle is held captive in the selector casting by a taper pin – according to the drawing – it is impossible to see visually.
The task appears to be to remove the input shaft housing, slide the selector off the input shaft housing and then to remove the tumbler gear. However in reality it is impossible to remove the input shaft housing as the selector will not slide off it due to the teeth of the tumbler gear protruding into the slot in the housing. Equally, it seems impossible to remove the taper pin + short spindle + tumbler gear as they are hidden at the bottom of the gearbox underneath the input shaft housing !!
I can only assume that Myford inserted the taper pin through the oil drain hole using a special tool, but extracting it would be another matter and would certainly need the gearbox upside down on the bench.
Has any reader replaced this item on their ML super 7 and can anyone advise me as to how this is possible. I am very distressed at having “broken” my treasured Myford. P L E A S E can ANYONE help me?
