Removing mt0 centre?
Home Forums Beginners questions Removing mt0 centre?
  • #320095
    bugbear6502
      @bugbear6502
      I suspect the live centre on my Simat has been there for at least a decade, possibly 2 or 3 decades.
      The mandrel is bored through to around 2.5 mm, so I can get a punch (of some kind) behind the centre to push it out.
      Before applying force, would applying something like PlusGas be helpful?
      BugBear
      bugbear6502
        @bugbear6502
        #320108
        bugbear6502
          @bugbear6502
          While I'm on; the spindle is steel, the bearings simply (precise) holes in the cast iron head stock.
          What lubrication should I be using? I'm guessing oil, not grease, since there are oil holes.
          BugBear
          #320120
          Ian S C
            @iansc
            I've got a little lathe with similar bearings, and I just use SAE 30 oil which is the oil I use for general oiling in the workshop. It probably wouldn't hurt to give the centre an over night soak. On my little lathe the centres have a radial hole so you can give it a bit of a twist, the spindle is solid, so no punching it out.
            Ian S C
            #320125
            Antony Price
              @antonyprice56876
              Hi Bugbear
              Is it possible to take the tail stock off, and upend it to allow a “drip –drip” of easing oil down the barrel, leaving it overnight, perhaps longer?
              Warming the whole thing in an oven before starting may also help by expanding the metal sufficiently to allow the easing oil to track down
              Don’t be impatient and apply force too early! If para 1 and para 2 fail, go back to para 1 and try again
              Tony
              #320126
              bugbear6502
                @bugbear6502
                This thread looks very informative – it's a Flexispeed, but very comparable. Lots of shots of how the thing goes together.
                http://www.modelenginemaker.com/index.php/topic,4025.0/all.html?PHPSESSID=mcpd8j2pdhdds8taqqbnp5ndq3
                (Although I don't have a handy Super 7 to make spares for the little lathe!)
                BugBear
                #320241
                bugbear6502
                  @bugbear6502
                  Good $DEITY.
                  There are two grub screws that hold the back-gear drive wheel and pulley-drive wheels to the mandrel.
                  To use direct drive, you fix the pulley to the mandrel by tightening its screw. Simple.
                  To use back gear, you undo the pulley screw, tighten the back gear screw, and cam-in the back gear pair.
                  If you tighten both screws, the mandrel locks (because it can't go round at 2 speeds at once!)
                  But If you undo both screws you can just pull the mandrel out! It's only held in place end-wise by the driver wheels…
                  So the mandrel is now vertical (as suggested), with some plus-gas inside it.
                  BugBear
                  #320675
                  bugbear6502
                    @bugbear6502
                    I up-ended the mandrel (the face plate was very handy for this) and dripped some PlusGas down it.
                    I don't have imperial drill bits, but a 2.5mm would go in, and a 3mm wouldn't. A visit to a friend who runs a bike shop, and a rummage in his scrap bin, gave me an old stainless spoke; the rolled-threaded portion of which would just go in the hole, and it mic'd at 0.123", so I suspect the hole is 1/8".
                    Having cut the spoke to have only 1/2" protruding, it was very easy to tap out the centre, with the mandrel held in soft jaws in a bench vice.
                    There was a little rusty discolouration. I can clean the centre easily, but can anyone advise on cleaning corrosion from inside the mandrel without damaging it?
                    BugBear
                    #320677
                    Anonymous
                      Either your mic or drills are off. In real money a 3mm drill is 0.118", so it should go in if a spoke measuring 0.123" goes in.
                      #320688
                      bugbear6502
                        @bugbear6502
                        Posted by Andrew Johnston on 09/10/2017 10:27:11:
                        You're ignoring the possibility of operator error!
                        What you say is quite true. I'll recheck for sanity tonight.
                        BugBear
                        #320694
                        Anonymous
                          Posted by bugbear6502 on 09/10/2017 11:25:52:
                          In the brave new PC world we're not allowed to say that, or even hint at it. smile
                          #320723
                          NJH
                            @njh
                            Forget the PC and get an Apple ……… although, thinking about it, I seem to recall that an Apple was the cause of all mankind’s problems,😳
                            Norman
                            #320726
                            Anonymous
                              Not that sort of PC. wink 2
                              And since I've miserably failed to get the new iPhone7 I've been given at work to do anything that doesn't involve having to register for iTunes I'll stick to apples from the trees in the garden.
                              #320738
                              Brian Wood
                                @brianwood45127
                                Bugbear,
                                The 'proper' way to clean up the socket is with a # 0 Morse Taper reamer. They are rare beasts I should think these days so I would suggest you shape a piece of soft wood to the form of the centre you have removed, soak it in Plus Gas and work it about in the hole while rotating the lathe spindle.
                                Examine from time to time to see what comes out. Pitting is less of a problem, you want to remove surface proud corrosion products. If you have a drill bit with a suitable MT fitting, try it with marking blue on it to see how well the tapers mate.
                                Regards Brian
                                #320741
                                Frances IoM
                                  @francesiom58905
                                  I bought a 0MT reamer from tracey tools – not that expensive – I wanted it to tidy up any problems with a Perris lathe
                                  #320871
                                  bugbear6502
                                    @bugbear6502
                                    There was a fault in the micrometer-brain interface.
                                    The rolled thread part of the spoke is 0.098"
                                    BugBear
                                    #320894
                                    Martin King 2
                                      @martinking2
                                      Hi Bugbear, long time no hear about you! Hope you are well. Regards, Martin (mahking51)
                                      #321003
                                      bugbear6502
                                        @bugbear6502
                                        Posted by Martin King 2 on 10/10/2017 17:25:36:
                                        Hi there Martin! Just messin' around with tools in my workshop, making nothing but happiness, as usual.
                                        BugBear
