Hopefully, the quill will have a slot, into which can be placed a tapered drift, specifically for removing a rbors withas tang.
Rather than making a self releasing drawbar, I made a slight mod to my RF25, (which has a 3MT quill).
Remove the left hand thread nut that holds the spindle pulley. Turn it down, to the across flats size of the nut, or just under, for a little more than the thickness of the plate that you choose, no more than half the thickness of the nut, to leave a register Take a piece of 6mm plate/flat bar, bore a hole in the centre to fit over the register in the nut, and then tap two holes, (M6?)equally spaced about the centreline, on a diameter, (say 13mm) larger than the corner/corner dimension of the nut.
(Use fine threads – my version is 1/4 BSF)
Take another piece of the same 6mm plate/flat bar, drill and tap on centreline for your choice of forcing screw.
Drill two clearance holes to match the tappings in the first plate/ flat bar.
Make up two clamp screws (Loctite knobs or nuts, onto studding?, or use long setscrews.
Screw these through the second plate. Fitting a nut to each one on the underside, will make them captive.
Place the plate with the register over the spindle. Refit nut, (register downwards) engage the register in the plate, and tighten nut.
To remove a MT arbor; slacken the drawbar by a half turn or a turn. Place the plate with the forcing screw over the drawbar, and screw the two long setscrews into the captive plate. (Stop just before the setscrews contact the pulley)
Tighten the central forcing screw onto the top of the drawbar, This should release the taper. If it doesn't, with the forcing screw really tight, give the top of the forcing screw a light tap with a mallet.
This should release the taper, without subjecting bearings to too much force.
