Posted by John Mitchell 9 on 01/12/2019 17:31:02:
I suppose it's a bit rich of me asking for your opinion on a Crusader? Given the price point and "deluxe" title I take it it can do everything 'well'?
Never assume anything, ask the supplier for confirmation.
The Crusader looks a competent machine. A mate of mine (who was a professional machinist) has the Warco equivalent, and he's pretty happy with it, although not as nice as the Harrison M300 he really wanted. He mentioned two issues. One, the Camlock system isn't always quite as slick as it ought to be. Two, if you remove the gap piece it is not guaranteed to go back in exactly the same place.
I have a M300 so it'll be interesting to compare the specifications, Crusader to M300, where they differ:
Centre height, swing over bed, swing in gap and between centres values are about 10% smaller
Length in gap is significantly larger than the M300
Slide travels are slightly less as you'd expect
Tailstock barrel diameter and travel are about 20% less
The Crusader has more spindle speeds but over a smaller range. I can't see the top end being a problem. I never run my M300 at top speed (2500rpm) due to the noise, but 67rpm at the bottom end may be a problem when screwcutting, depending upon the reaction time of the operator
Feed rates are a slightly narrower range, but not significant. On the M300 cross feeds are half the longitudinal feed, on the Crusader it's more like a quarter
Metric threads are over a smaller range, fine and coarse pitch threads missing
Imperial threads are missing some coarse tpi, which I suspect won't bother the OP
Module threads are very similar and DP threads over a wider range, although again I don't suppose these are relevant to the OP
It would be well worth asking for a detailed list of the threads that can be cut – as always the devil is in the detail
Leadscrew pitch is half that of the metric M300
The motor power is half that of the M300. Should be adequate for making small bushes, but not for hogging. I've stalled my M300 when roughing, so beware. It's not clear from the spec whether the Crusader has a 415V 3-phase motor, or whether the OP has 3-phase available.
The Crusader weighs not much more than half the M300
I think the Crusader should be more than capable of the jobs the OP has, but I'd check everything with the supplier rather than get surprises after purchase. Ask about saddle and slide locks – the M300 has them, and they work, does the Crusader? I believe the new price for a M300 is around £20k, so the Crusader s a lot of lathe for the money.
