radial arm drill.
radial arm drill.
Home › Forums › Workshop Tools and Tooling › radial arm drill.
  • #18230
    mick70
      @mick70
      #262212
      mick70
        @mick70
        been offered a radial arm drill that was designed for woodworking with dead motor.
        guy says to fast for metal working is going to get me speeds later.
        i have a spare drill press motor from metal working one.
        am thinking if pulleys are same i can just put motor on it.
        if not will get speed controlled motor for it.
        other than speeds is there any reason i can't use it for metal working?
        #262215
        Emgee
          @emgee
          If you can overcome the spindle speed issue much will depend on the rigidity of the machine and the size of holes you wish to drill. Metal working Radial arm drills are normally heavily built to withstand very considerable forces without distortion, I don't expect a woodworking radial arm drill to be so substantial.
          Emgee
          #262269
          Dave Halford
            @davehalford22513
            be OK for light use or drilling sheet metal if you need holes at 90deg go very light pressure
            #262297
            alan frost
              @alanfrost17805
              An opportune post maybe to point out that Axminster do a range (well at least 3 models ,maybe more ) of radial drills meant for metal working. i have the cheapest one which IMO is still incredible value and was even more so when I bought it. The ability to tilt the head and to increase and decrease the throat I have found incredibly useful over the 7-8 years i've owned it. I have no connection at all with Axminster apart from always being left a happy customer.
              The range also have rack operated tables ( once you've had one yoiu won't ever want to return to lifting and lowering tables with muscle) and the keyless chuck on mine is high quality and saves hours of time when constantly changing drill bits.
              Alan Frost
