Posted by ChrisB on 01/02/2019 08:34:52:
Posted by Tim Stevens on 31/01/2019 14:51:40:
A dog clutch as shown above would have an added advantage. It would be very easy to add an adjustable rod, running leftwards from the saddle, which would disconnect the clutch at a set position. This would enable you to cut threads without the worry of overshooting. So, I'm going to have a good look at my ML7 to see if I could make something up.
Regards, Tim
Exactly my thoughts Tim, with an auto-stop like you mention a lot of the hassle of threading to a shoulder would be eliminated.
As for the guard on the lead screw – I don't mind loosing it (as a matter of fact I took it off already). I don't think I would need a separate wheel on the lead screw if my thinking is correct : Let's say I'm threading to a shoulder, dog clutch disengages at the preset point. Retract the tool and turn of the lathe. Switch it to reverse and turn on the lathe engage dog clutch and return to starting point. Repeat for next pass.
Is my reasoning correct or I'm missing something?
If it is, you'll get a root diameter undercut from the delay between the clutch decoupling and you stopping the spindle. In many cases this is OK, but in pressure-bearing components often not – the thread is supposed to taper out to full diameter without an undercut.
But if the spindle does more than one rev to produce one rev of the leadscrew driven gear, even if you have a single-tooth dogclutch, I'm struggling to see that you'll automatically pick up the thread correctly on the next pass, because only the rotational relationship to the final drive is fixed, not to the spindle.
And back to you and any others: Is my reasoning correct or I'm missing something?
Someone earlier suggested putting the clutch between spindle and geartrain. I think that'd work, but it's a helluva different proposition to achieve.
Edited By Mick B1 on 01/02/2019 10:14:47
