Posted by fizzy on 06/10/2019 15:22:29:
The way I thought about it is….if the boiler were just a strong sealed container (which it effectively is) with water in it and heat applied, the water would turn to steam, the pressure would go up. Let it cool down and the pressure comes down to exactly where it was when you started. Nothing can have changed. The only difference when using it for real is that there will be less water in it when it cools down, assuming no more has been added. Ive tested this with a smaller boiler with no clack, running the water level down whilst maintaing 40 psi driving a D10. Closing the steam valve and after cooling there is absolutely no negative pressure that I can detect.
Fizzy's thoughts follow early steps in the path made by Newcomen, Watt, Carnot, Stirling, Joule, Clausius, Otto, Rankine, Diesel and other geniuses!
For many years I imagined steam and internal combustion engines as simply driven by pressure. It's a useful model but turns out to be only a small part of the story. Looking deeper it's found the prime mover is heat, not pressure.
When heat is applied to water it warms up linearly until it reaches boiling point. This is called 'Sensible Heat'. At boiling point something strange happens: a hefty blob of extra heat is needed to convert water from a liquid into a gas. This is called Latent Heat. Then sensible heat takes over again and raises the temperature and pressure of confined steam linearly.
Water requires rather a lot of extra energy to convert from water to steam – about 2300kJ to convert 1 kilogram of water into steam. The effect can be seen in the kitchen where it takes a long time to boil a saucepan of water dry. Almost all the energy coming from the cooker ring is used to convert water to steam. The temperature of the pan doesn't rise above 100°C, because it's kept cool by the water. An empty aluminium saucepan soon melts.
One way of visualising steam being converted to work is to imagine it applying pressure to a piston, more accurately the piston converts energy released by expansion into mechanical work by cooling steam. The maths of the latter explanation is much more informative and complete.
The realisation that heat, rather than pressure, drives engines is important. For example, it becomes possible to calculate how big an engine will be needed to do a known quantity of work, and how long it will take to do it, and how much fuel will be consumed in the process. In the 19th century, heat theory (Thermodynamics) predicted correctly that internal combustion engines could be made with a much better power to weight ratio whilst being far more energy efficient than any reciprocating steam engine. It predicts when it will be impossible to improve a heat engine beyond a certain limit. It also anticipated that steam turbines could be made more efficient than any internal combustion engine, which is handy to know when building power stations. The same theory explains refrigeration.
Fizzy said: 'Let it cool down and the pressure comes down to exactly where it was when you started. Nothing can have changed. The only difference when using it for real is that there will be less water in it when it cools down, assuming no more has been added.' This would be correct, except the amount of energy in the boiler changed massively and might have altered the balance.
'Might'! But to create a vacuum inside the boiler, it's necessary for it to have done some external work. However, even without driving a piston or heating radiators, leaks or stretching the metal of the boiler does 'work'. So a boiler might collapse.
Only a completely sealed and rigid container would behave as Fizzy suggests, which is 'not wrong' – there are plenty of real world examples. For instance, I don't think boiling a Carbon Dioxide soda syphon Sparklet would cause it to collapse on cooling. (As Sparklets are about 900psi at room temperature, the thought of one going pop inside a pan of boiling water puts me off cooking one!) One reason pressure vessels need to be operated and maintained carefully is the rules change depending on circumstances. A faulty valve can cause an otherwise sound boiler to collapse or explode. In full-size there have been many nasty accidents.
Ought to be emphasised that the size of the boiler is all important. It limits their capacity to store energy. The boilers used in model engineering are tiddlers, meaning not much energy is involved even if one goes badly wrong. In addition they are usually made of copper which tends to split rather than explode when a boiler is over-pressed. Slowing down the energy release makes small copper boilers even less likely to hurt anyone. Likewise the surface area of a model boiler collapsed by an accidental vacuum is tiny compared with a CRT, ie the boiler is safer than an old-TV set. It's misleading to describe model boilers as 'bombs'. Yes they're capable of causing injury, but they're not in the same league as a hand-grenade…
