qctp holders used on the mill
Home › Forums › Beginners questions › qctp holders used on the mill
  • #266822
    Russell Furzer
      @russellfurzer50760
      I have just had a task requiring the holding of a 5/8 bar for milling and used the boring bar holder from my AXA tool post to hold it. Clamped the thing to the mill table. worked a treat.
      #8392
      Russell Furzer
        @russellfurzer50760
        #266838
        Muzzer
          @muzzer
          I take it you don't have a milling vise then? You could also simply bolt the bar against one of the tee slots with a strap and 2 tee bolts – more rigid perhaps.
          #266875
          mark costello 1
            @markcostello1
            Good ideas always welcome.
            #266908
            Russell Furzer
              @russellfurzer50760
              Hi Muzzer
              I do have a milling vice. But holding the round bar between flat faces didnt seem as secure as the tool holder.
              I didnt use the tee slot because I wanted to access all of the end of the bar without hitting the edge of the slot.
              The QCTP holder was very easy to set up too – I posted because I thought that this was a good solution to the job that I had on hand and that others might consider it as an arrow in their quiver.
              #266909
                Posted by Russell Furzer on 16/11/2016 22:30:28:
                Well said, Russell … and duly noted
