Hi David, Thanks for that info.
My Allchins TE that I am building does not have a snifter valve so a couple more questions come to mind.
1. Is a snifter valve used when cylinders have either piston valves or slide valves, or only when piston valves are used. (I am thinking a slide valve can lift to clear a vaccum)?
2. Is the snifter valve only applied when superheating is used for the express purpose of using the vaccum created to cool and protect the super heaters, so if super heaters are not used a snifter valve is not used? (Then any vaccum would be used to brake the engine).
Cheers
Nigel
