Power Hacksaw run off
Home Forums Beginners questions Power Hacksaw run off
  • #84162
    Peter Simpson 2
      @petersimpson2
      I have nice Meddings HS4 power hacksaw which does not cut the bar stock quite square. As it cuts it runs off away from clamped bar stock. It appears to cut with the same error every time. Other than the gib strip there does not appear to be any adjustment to correct this error. Has anybody out there had similar issues with power hacksaws.
      Is a 14″ power hack saw blade the total length of the blade or is it 14″ between fixing hole centres?
      Any responces greatfully received
      Peter
      Peter Simpson 2
        @petersimpson2
        #84163
          Does it do it with a new blade, if the old one has lost some set on one side the blade will cut towards the other.
          J
          #84164
          Peter Simpson 2
            @petersimpson2
            Hi Jason,
            Just ordered new blades, hope this sorts it out.
            Peter
            #84165
            SteveW
              @stevew54046
              Ii think thiis is a ‘feature’ of most power hacksaws. As Jason indicates I also think caused by an uneven set but often still present in new blades. We underestimate the amount of feedback we provide with a hand saw in order to achieve a (fairly) straight cut.
              SteveW
              #84169
              _Paul_
                @_paul_
                I have both “Rapidor” & “Qualters & Smith” donkey saws, and no matter how carefully I set up the work or the machine/s they will always cut slightly off.
                I put it down to the set on the teeth, I have tried both 6 & 14tpi blades & reversing them so it cuts on the forward stroke and not much difference either way.
                The 6″ “Qualters & Smith” is certainly the better of the two and quite bizarrely it seems more accurate when cutting through bigger stock ie. > 2″ I can only attribute that to the better quality feed adjustment this machine has.
                Paul
                #84175
                Engine Builder
                  @enginebuilder
                  This one cuts without any run off and can handle large sections.
                  #84177
                  Les Jones 1
                    @lesjones1
                    Hi,
                    Does anyone know how much the plans cost for the myfordboy saw ? I am impressed by its accuracy.
                    Les.
                    #84190
                    Russell Eberhardt
                      @russelleberhardt48058
                      Posted by Les Jones 1 on 08/02/2012 18:30:32:
                      From the video it looks as if his foot was impressed by that large lump he cut!
                      Russell.
                      #84196
                      George Scollay
                        @georgescollay44108
                        Hi, Les I think the plans were about 10 pounds, I had a set from Myfordboy last year and they are very good, I have just got the saw made now and seems to work very well but I did not get it as accurate as him, but according to him it depends how well it is made,if you send him an email he will let you know the price
                        #84199
                        Les Jones 1
                          @lesjones1
                          Hi George,
                          Thanks for that information. I have been thinking of buying one of the 6 x 4 bandsaws or the Seig power hacksaw but I do not really have room for them. Myfordboy’s design looks much more compact.
                          Les.
                          #84212
                          Steve Wan
                            @stevewan33894
                            Hi folks
                            I suspect that the saw blade is not aligned properly that causes the run off.
                            I’m in the process of making a compact power hacksaw with ample info from various designs on the web. The frame itself is a 11″ G-clamp, heavy for the weight to saw and it will be driven by duplex pulleys of bicycle chain drive and step pulley.
                            I shall look into the ‘Run off’ problem soon once I get my main saw frame done.
                            Making a power hacksaw is challenging than buying one. These days bandsaw blades are expensive for model engineers too.
                            Steve
                            #84214
                            Ian S C
                              @iansc
                              If the amount of run out is consistant, you can pack up the work to compensate, if nothing else works. Ian S C
                              #84250
                              RICHARD GREEN 2
                                @richardgreen2
                                Hello All,
                                In my own engineering business over the years I have had three serious power hacksaws, an Ercole 300 mm, a Speedax 9″ and I’ve still got a Qualters and Smith Bulldog 200 ( 8″ ),
                                About 10 ish years ago I had trouble with the Speedax cutting crooked, even with a new blade fitted,
                                I had a representative from a Sheffield power hacksaw blade manufacturer call on me to have a look at it, the saw was in reasonable condition with no serious wear or slack in the slides etc,
                                He told me the most important thing with a power hacksaw is blade tension !
                                Think about it,……… when the blade warms up during cutting, it will expand length wise reducing any blade tension there is, the blade can then lose it’s vertical alignment due to it being slack, there’s a lot of vertical pressure on the saw blade, so it’s going to try to flop over a little bit if it can ( that’s the only way it can go ), once it has started cutting crooked it’s not going to straighten up, only get worse !
                                Part of the answer is to always use coolant or some kind of cutting oil to keep the blade cool,
                                Of course starting with correct blade tension is important, but how we determine that I don’t know, the representative had an all singing all dancing test gauge, I think was made by Starrett, but I’m not sure,
                                Anyway, different blade sizes would probably mean different tensions ?
                                The Qualters and Smith saw usually cuts straight, but I always use a good quality cutting oil, whatever material I’m cutting, and really flood the blade and material to keep it cool.
                                Hope this helps, I would be interested in your ideas of getting the correct blade tension.
                                Richard.
                                #84260
                                George Scollay
                                  @georgescollay44108
                                  You can contact Myfordboy at Myfordboy@yahoo.co.uk the saw plans are very good
                                  #84281
                                  Steve Wan
                                    @stevewan33894
                                    Hi guys/Richard
                                    Thanks for the tip! Yup, heat generated by sawing will bow the blade. Has anyone here built his very own compact power hacksaw? I like to know what other measures to take to prevent run off with all the pointers commented here in mind.
                                    By far, there’re only 2 types of casting supply for power hacksaw in the UK by Blackgates and Westbury (ceased in 2006). Wonder are there others? Myfordboy is relatively new.
                                    Steve
                                    #84288
                                    Ian S C
                                      @iansc
                                      I read not that long ago about the tension in blades, it was conciderable, hundreds of pounds, I must have a look around. Ian S C
                                      #84301
                                      DMB
                                        @dmb
                                        hello all,
                                        I want a small portable hacksaw m/c, possibly with a view to getting rid of the space eating bandsaw and I found a design in an old ME – Vol. 82 No. 2042 27/6/1940.
                                        The bandsaw also needs expensive good makes of blades – pay rubbish price, get rubbish. At least with the other type ordinary blades can be used and even good ones last a long time. The old 1940 design probably needs long bearings to guide it to cut straight/square. I have necessary ali angle motor and worm reduction gear so will probably tackle this job soon.
                                        Steve Wan
                                          @stevewan33894
                                          Hi John
                                          We’re in the same boat needs space and saw blades are cheaper using power hacksaw. I don’t have an angle motor and saving my worm gear for my small horizontal mill project. The long bearings you were saying caught my attention.
                                          I have a drawing with the support bar milled with slots to hold moving saw frame instead of using collars which may have contributed to the run off problem.
                                          Do you like to share more design ideas via email?
                                          I have just made the heavy frame out of 11″ G-clamp using half the hacksaw blade. All necessary metal blocks/pulleys are purchased. Soon I shall go into the finer aspects of this challenging project
                                          Steve
