Polly Steam Plant
Polly Steam Plant
  • #454960
    Joseph Harland 1
      @josephharland1
      Hi All,
      I'm in the middle of making a copy of Tubal Cain's POLLY.
      Do I need to remove the remnants of silver brazing flux from inside the boiler and if so – how?
      Joe Harland
      Joseph Harland 1
        @josephharland1
        #454964
        michael howarth 1
          @michaelhowarth1
          It will dissolve when you pickle and rinse it.
          Mick
          #454990
          Joseph Harland 1
            @josephharland1
            Thanks Mick, I was worrying about how to rinse out the inside – there are only 2 small openings.
            Joe
            #455010
            Norman Billingham
              @normanbillingham91454
              We teach students on our basic course at SMEE to make Polly. So far I think we've had about 120 made. We use copper tube to make the boiler and just give it a wash through with hot water to remove flux residues after brazing in the end plates. We've never had a problem. It's actually more important to wash thoroughly when you've used soft solder with Bakers fluid flux as in soldering the firebox to the base – chloride residues from the flux can be corrosive to steel.
              Good luck with the build
              #455450
              Joseph Harland 1
                @josephharland1
                Thanks for the advice Norman (and Mick), I am carrying on.
