Petrol tap thread
Petrol tap thread
Home › Forums › General Questions › Petrol tap thread
  • #252940
    Bazyle
      @bazyle
      Got a small lawnmower petrol tap similar to this as used on some old qualcast mowers I think.
      The thread seems to be 3/8 dia tapered and about 29 tpi. ie between 28 and 30 on my thread gauge and not matching a metric one either. Finer than common fasteners, not as fine as UNEF(32tpi). Anyone know the standard?
      in passing came across this which didn't help but is an interesting list of threads.
      #24706
      Bazyle
        @bazyle
        for lawnmower tap
        #252942
        Bob Youldon
          @bobyouldon45599
          Whato Baz,
          Try 1/8" BSP
          Bob
          #252949
          Maurice Taylor
            @mauricetaylor82093
            I made a fitting for a 30 year old Qualcast petrol tank about a year ago and it was 1/8" BSP
            #252954
            Bazyle
              @bazyle
              Thanks, I looked at 1/4 BSP tpi as I thought the differences between name and sixe was only one step not two so should have been more attentive to the dimensions. I think I have a tap, somewhere…….
              #253201
              Nick Hughes
                @nickhughes97026
                Seems youv'e found the thread.
                Here's a link to some obscure and standard threads: **LINK**
                Nick.
                #253265
                Tim Stevens
                  @timstevens64731
                  Remember that there are two versions of British Standard Pipe Thread – one Parallel (for proper tightening against a washer, etc) and Tapered (to tighten into the hole, often using some sort of filler compound). The Parallel version is the same pitch, and fits about half-way along the Tapered when they are screwed to gether, so you can be caught out.
                  Cheers, Tim
                  #253321
                  Bazyle
                    @bazyle
                    well I found my tap (screw thread for cutting) and it is tapered laugh
