Pet peeves!
Pet peeves!
Home › Forums › General Questions › Pet peeves!
  • #424386
    Mark Gould 1
      @markgould1
      I’m sure we all have one and mine regards to my favourite Mitutoyo micrometer. It only fits in the box when the anvils are nearly touching. And it’s one of those old Mitutoyo’s with the mechanical numerical wheels so every time I have to store it I worry about the wear and tear to that rather intricate bit of kit.
      Why didn’t they design the box so that the thing would fit with the thimble “extended”?
      Mark
      #26777
      Mark Gould 1
        @markgould1
        #424398
        old mart
          @oldmart
          I have that problem with some battery drills. They won't fit in the box if the jaws are projecting from the face of the chuck.
          #424403
          ega
            @ega
            Posted by Mark Gould 1 on 15/08/2019 21:12:51:
            Mark
            They did:
            But, so far as I know, M&W didn't!
            #424407
            FullaFlava
              @fullaflava
              Drill boxes where the small drill bits fall out and jam the lid so it won’t open or require removing most of the other bits to retrieve the dislodged ones.
              Blow moulded tool boxes for corded tools which require the cable to be just so before you can close the lid.
              Grease guns. Never met one I liked.
              #424411
              Robin Graham
                @robingraham42208
                Dog who howls insanely every time I descend to my cellar workshop because she thinks that's where I keep my pork scratchings. She's right in that, but makes the mistake of thinking that the only reason I ever go down there is to scoff unhealthy snacks. A very peeving pet!
                Robin.
                Edited By Robin Graham on 16/08/2019 01:12:20
                #424413
                Mark Gould 1
                  @markgould1
                  Posted by ega on 15/08/2019 23:57:52:
                  Mark
                  They did:
                  I need a box like that! Haha exactly what I was referring to,
                  Mark
                  #424420
                  Jan B
                    @janb
                    3-D print and make a box the way you want it.
                    Jan
                    #424442
                    Graham Stoppani
                      @grahamstoppani46499
                      Why do manufacturers stamp the drill size just where the chuck jaws go?
                      #424443
                        Mark
                        They did:
                        Looks to me that they only half thought it through as the mic will only fit if open to less than 1/2"
                        #424449
                        Robert Atkinson 2
                          @robertatkinson2
                          Half way is the ideal storage position, no more than 1/2 max turns no matter what you measure next.
                          My pet peeve is people promoting illegal car modifications like DPF / EGR deletion or LED lights on motoring forums without noting they are illegal
                          Robert G8RPI.
                          #424451
                          Mick B1
                            @mickb1
                            Mark
                            Wow! Does your 0,01mm counter still work? Mine jammed immovably about a month after I bought it in 1976, so I took it out – but I still use the Imperial vernier mic!
                            I wonder if I could buy a new counter?
                            #424505
                            Mark Gould 1
                              @markgould1
                              Mick, I bought mine second hand and yes it still works but I am bery gentle with it and having to screw it closed to get it in the box makes me cringe every time. I think I’ll take Jan B’s advice and construct a new case.
