Perpendicular Drilling
Home › Forums › Beginners questions › Perpendicular Drilling
Viewing 12 posts - 26 through 37 (of 37 total)
  • #232255
    Mark P.
      @markp
      I find that my pillar drill is only good for a bit of blacksmithing ie just sticking holes where pin point accuracy is not required.
      Mark P.
      #232265
      John McNamara
        @johnmcnamara74883
        When contemplating how to process a job accuracy beyond what is needed can be a great time waster. does the job really need to position the hole with pinpoint accuracy or will within maybe .0015" to .002" do? achievable on a good day if my glasses are clean.
        I can set a drill in key less chuck on the pillar drill in a few seconds, Maybe a spotting drill first if needed, Position the work in vice and set the centre pop on the work under the drill in less time than it takes to write this. If needed In goes a chamfer cutter to remove the sharp edges around the hole flip the work do the same on the other side and the job is done.
        Alternatively do it in the vertical mill this will require centre finding the punch mark locating x and y, the big table is heavy and there will be a fair amount of winding. then Fitting a drill chuck in quill and tightening up the the draw bar…. as we all know the wrong tool is always in the draw bar… then finally drilling the hole.
        Yes with care I can get better accuracy maybe one or two thousandths of an inch better, The purists will claim they can do .0001" (In their dreams) unless they have a jig borer in temperature controlled room! yeah.
        Time waits for no one.
        Martin Kyte
          @martinkyte99762
          I thought the OP's issue was getting a vertical hole?
          Martin
          #232267
          Daniel
            @daniel
            Mark – summing up my sentiments right now wink
            John – (sorry for referring to you as David, earlier), It was while trying to make Mr Pete 222's Wobbler engine, that the problem came to light. He kept emphasising the importance of the perpendicularity between the cylinder block and it's pivot pin. Upon screwing in the pivot pin, even with all the optimistic enthusiasm I could muster, the thing was anything but perpendicular. I would guess a good 10° off.
            The point regarding appropriate accuracy is one I subscribe too also. However, in this example, it would have been an abuse of the word, to have used it in relation to what I had just produced.
            Martin – Yes, my problem was to get a vertical (ish), hole. However, with all the input from the others, I would guess that achieving a hole of any predefined angle would yield similar, albeit random, results.
            #232278
            Ian P
              @ianp
              In my experience no matter how perpendicular the drilling spindle is to the worktable the chances of a hole being absolutely perpendicular are not very good. If there is the slightest difference of position between the start of the hole and the axis of the drilling spindle the drill will bend, maybe imperceptibly at first, but as the hole proceeds the drill will increasingly divert from where it should be. Having the work clamped down actually makes it worse.
              If the part to be drilled has a flat underside surface than can sit on the worktable I frequently do not use a vice, once the drill has created a dimple (and I know its in the right place) I peck drill whilst frequently rotating the job half a turn at a time. By turning the job to different positions any spindle/table misalignment is cancelled out
              Ian P
              #232367
              Gwil
                @gwil
                Hi Daniel
                Don't know how relevant this is, but anyway –
                OK, the pivot screws into the cylinder. Has the pivot got a shoulder, larger in diameter than the threaded part, turned on it? If it has, and the shoulder doesn't seat squarely against the cylinder, then there is something wrong with the hole. If there is no shoulder and the design relies on the thread coming to an end to locate the pivot, there is a good chance that it may end up cocked over anyway (unless the thread is a very close fit) even if the hole is perfect. Another thought – the hole may be perpendicular but was the axis of the tap when it went in?
                Just thinking aloud …
                #234133
                Daniel Gilbert 1
                  @danielgilbert1
                  I don't know if this is the right place to ask, but I am trying to drill three holes on porcelain tea saucers. My challenge is getting a hole started as the drill bit constantly slides all over. I did see that there are drill guides but it cannot lay flush on the plate as the plate is not flat. The lip goes up on the edges.
                  I am using a diamond drill bit and start at an angle.
                  I hope you have some tips for me as this is frustrating!
                  #234161
                  Gordon W
                    @gordonw
                    Don't know about drilling porcelain with a diamond bit, but have drilled a few tiles. Put a bit of masking tape on and drill thru' that.
                    #234164
                      Two options
                      1. make a drill guide like the one shown from something that is a bit flexible, lid off a plastic container will do, just use a normal drill to make a hole the size of your diamond coated drill. Then hold the flexible guide against the saucer and away you go.
                      2. Not for the faint hearted or those who don't know what they are doing, tilt the drill over slightly, guide the end of the drill bit with your finger and as it starts to cut slowly bring the drill perpendicular to the surface.
                      I drill a lot of holes through ceramic, glass and porcelain tile and the above two methods work fine.
                      Masking tape is more suited to the spear point tile drills than the diamond coated ones though I use a centre punch to start them, again need to know what you are doing.
                      #234173
                      Ian S C
                        @iansc
                        To drill through glass, hardened steel and the likes, I made a drill from a bit of tube that slides on a shaft that fits in the drill chuck on the vertical milling machine. The tube is spring loaded to bear on the artcel being drilled, the cutting medium is grinding paste.
                        Daniel, you should be able to find a suitable hole, maybe a washer, then glue it to the surface of the saucer and drill the hole.
                        Ian S C
                        #234174
                        Daniel Gilbert 1
                          @danielgilbert1
                          Thank alot, you guys are GREAT!
                          #234342
                          frank brown
                            @frankbrown22225
                            Good drilling practice, coolant, rigid fixing, tight chuck bearings, well ground drills and finally "pecking". That is taking a very, very small cuts, say 1/2 a turn band pulling the drill out, yes its laborious but it makes sure that the swarf is removed and does not jam in the side of a fluke so deflecting the drill. The problem is once the drill deviates from the true vertical, the forces then increase the deflection. An American website has a lot of chat about this and it seems that a diam/depth ratio of 1:48 still lead to holes being within thous of their correct position.
                            Frank
