Parvalux motor with gearbox
Home › Forums › Beginners questions › Parvalux motor with gearbox
  • #257825
    Roger Hulett
      @rogerhulett83124
      I have just been given a Parvalux electric motor with a right angle drive gearbox.
      Can anyone suggest a practical use for this or should I stick it on fleabay?
      #8306
      Roger Hulett
        @rogerhulett83124
        #257827
        Hacksaw
          @hacksaw
          Saw this adaptation.. !! If link doesn't work , look in on -Retrorides -" readers modifications " http://retrorides.proboards.com/thread/192636/power-vice-bush-mechanic-style
          #257831
          Vic
            @vic
            Depends on the power output and gearbox ratio. Maybe it could be used for a power feed for a mill table?
            #257833
              @mike89748
              You don't tell us the size of the motor, but it sounds like a Telex machine motor I once had. I took off the gearbox, added a pulley, and used it to power a small drill sharpening machine. Could be the basis of a grinder mounted on your lathe's cross slide?
              #257840
              duncan webster 1
                @duncanwebster1
                I used a Parvalux 240v 1400 rpm squirrel cage motor with the gearbox removed to drive a Perris lathe before I went 3 phase. I know overkill, but I got the motor and vfd as part of a deal. The Parvalux is now driving a little pillar drill. My drill sharpening machine is driven by the motor off a diswasher pump. Never throw anything away!
                #257843
                Eugene
                  @eugene
                  Just expanding on Duncans' post, the diddy sized ones are a popular choice for sensitive drilling set ups as per the George Thomas pillar tool.
                  Eug.
                  #257844
                  Ajohnw
                    @ajohnw51620
                    Some universal ones run at 4000 rpm – good speed for a 4" or so tool grinder. A lot depends on the motor power and type.
                    frank brown
                      @frankbrown22225
                      We used 100s of small ones to rotate rotary transformers for voltage stabilisers, 16V field + 8V armature DC 50/100:1 gear box? sort of 8" end to end.
                      Frank
                      #257889
                      Danny Hegh
                        @dannyhegh44921
                        If it's slow enough ,build yourself a spit roaster it saves wearing the dog out ; ).
                        #257893
                        Robbo
                          @robbo
                          roger
                          How about a power hacksaw?
