parallel flute end mills
Home › Forums › Beginners questions › parallel flute end mills
  • #155064
    nigel jones 5
      @nigeljones5
      What are these used for? Why not helical?
      #7193
      nigel jones 5
        @nigeljones5
        #155066
        Frank.N Storm
          @frank-nstorm18349
          Posted by fizzy on 11/06/2014 21:28:21:
          Best as doorstop for a very small door….
          I bought one, years ago, and found it totally useless.
          Regards, Frank
          #155070
            (a) According to this supplier:
            "For tight tolerance slots and keyways."
            (b) Because helical ones don't do that very well.
            #155090
            John Stevenson 1
              @johnstevenson1
              I would not say they were totally useless or you can throw every router cutter away as these are mainly parallel.
              They are good for light finishing cuts.
              #155117
              roy entwistle
                @royentwistle24699
                I find them ideal on brass and gun metal
                Roy
                #155125
                Muzzer
                  @muzzer
                  If you are doing any maching using the edges on the end of the cutter, the helix angle will be related to the material it's intended for. So aluminium would require a fast helix, copper and brass a slow (or parallel) helix and you can even buy a reverse helix. I suspect the latter is actually best used for thin sheet material, as it will push the work against the table.
                  Of course, you could have a parallel flute cutter with any kind of cutting angle if you are mainly cutting radially and I expect you can get different combinations of helix angle and cutting angle according to both material and type of cut. But one advantage of the spiral is a smoother cutting force which is presumably why parallel edged cutters are best used for light finishing cuts.
                  Murray
                  #155155
                    I made an 'emergency' slot drill from silver steel to the 'LBSC' design. Mill away two sides then file relief on the edges and ends. Harden and stone an edge. To my amazement, it worked, and also worked well for light facing cuts using the end.
