thanks for all replies..sorry I messed up my post..typing on small screen…I thought ml2 pinion was 25dp ,a non standard size I believe , have been checking out model car motor pinions tamiya etc..but these are close ,but hardened thro, not practical to bore out at .250″ …the shrink fit idea, not sure would work on such small dia..brazing ,iI would like to try. going to increase shaft to 8mm silver steel ,and reduce end slightly to locate a gear..12 tooth gear quit small, might take a 7mm hole..also working on a idea..pair reduction gears to slow down hand traverse..possible room for these , on front of apron..bag full o cheapo plastic gears, to get the geometry right ,before I buy any metal gears..they pricey..the obvious answer would be new racks an pinion but im not a lottery winner..last note, I scrapped original spindles , new ones en24t…screwcut nose same as ml7, worthwhile, i am happy to receive any comments forthcoming…..footnote..all slides off the lathe have been machined and scraped, new gibs from bronze, used ml7 feedscrews on slides..slow but sure..thanks
