Odd sized strong bar
Home › Forums › The Tea Room › Odd sized strong bar
  • #35513
    Plasma
      @plasma
      Is this just a mistake?
      #414796
      Plasma
        @plasma
        Hi all,
        I bought what on the face of it is a 1/4 drive strong bar but when received will not fit my sockets.
        It 6.99mm across the square so near on 9/32nds.
        Is it just a poorly made quarter drive or is there some obscure 9/32 drive socket set out there?
        Regards Mick
        #414797
        Plasma
          @plasma
          Here is the item, any thoughts please.
          #414803
          Brian G
            @briang
            A quick google shows that you have a 1940s US made Plomb "Wright Field" 9/32" drive flex handle. There is an article on them here Alloy Artifacts
            I wonder if the arrow is the US military's equivalent of our "crow's foot"?
            Edit:  Snap-on also made 9/16 tools https://www.collectingsnapon.com/index.php?page=socket_sets/C9-32inch/9-32%20intro
            Edited By Brian G on 18/06/2019 09:16:49
            #414815
            Hopper
              @hopper
              The range and depth of knowledge on this forum just never ceases to amaze.
              #414826
              larry phelan 1
                @larryphelan1
                Hopper, YOU AINT SEEN NOTHING YET !!
                No matter what the question, someone here has the answer.
                #414860
                Ian S C
                  @iansc
                  A case of you buy our strong arm, you buy our sockets.
                  Ian S C
                  #414889
                  Vic
                    @vic
                    I’m still surprised the French don’t use 10mm and 15mm drives! cheeky
                    #415008
                    Ian S C
                      @iansc
                      Some of the 1/4" drives seem to be nearer to 6 mm, the sockets seem OK, just the drivers are a bit sloppy.
                      Ian S C
                      #415012
                      paul rushmer
                        @paulrushmer83015
                        Hi
                        Some where I have a set bought from Wistons many years a go, Interestingly this had an od 1/4 drive socket in it that fitted Meccano square nuts.
                        #415015
                        Martin Hamilton 1
                          @martinhamilton1
                          Posted by paul rushmer on 19/06/2019 13:07:35:
                          Hi
                          Ah Wistons see my cat, those were the days. They used to sell some great items @ very good prices, really missed them when they shut up shop.
                          #415020
                          ega
                            @ega
                            Strong bar or flexible handle? On reflection perhaps the former name (new to me) is a better one.
                            #415024
                            Plasma
                              @plasma
                              I have always known the tool as a strong bar or breaker bar from my motor vehicle engineering days.
                              Flexible handle fits nicely too but the ones I was using were 1/2 drive and 18 to 24 inches long so not really a handle.
                              It was very satisfying to crack the wheel nuts with one, using the inertia of the wheel to exert a high torque on the nut and free it. Sort of spin the wheel clock wise then pull up on the strong bar and arrest the spin suddenly. Hard to describe but very effective.
                              Mick
                              #415041
                              Bazyle
                                @bazyle
                                I wouldn't call anything less than 2ft long a breaker bar but I see Snapon call a mere 15inch one thus. I would call it a swivel joint handle.
                                #415049
                                Vic
                                  @vic
                                  Yes agreed. The 1/2” drive Britool breaker bar I bought for tight wheel nuts when I was a mechanic is at least 20” long and Snap-On made even longer ones. Anything in 1/4” or even 3/8” drive is hardly a breaker bar in my opinion.
                                  #415061
                                    Supposed to be cadmium plated according to the link.
                                    Yours looks like the plating has been stripped to bares steel. I hope the seller remains in good health…
                                    AJW
                                      @ajw
                                      I've got one exactly the same!
                                      It wouldn't fit anything, but it does now as I have made it fit! Just take a suitable amount off two faces.
                                      Alan
                                      #415094
                                      Howard Lewis
                                        @howardlewis46836
                                        I used to remove / refit the sump plugs on our Renault cars using a 3/8 square ratchet and extension, It was a slightly loose fit in the 10 mm square socket of the plug, but worked without problems.
                                        Possibly the Continentals have their own standards for socket drives, (although they use BSP threads on water fittings, calling them "Gas" )
                                        Or a similar strategy to that of Ford in needing a 7 mm Allen key for the calliper retaining bolts on some models?
                                        Bosch used a triangular head on the plugs retaining the governor shaft on the EPVE injection pump. Guess the only place where you buy an expensive triangular socket?
                                        Similarly, Japanese manufacturers of "cassette" injection pumps used five sided heads on their retaining bolts!
