Nice plastic cover for a length of metal.
Home › Forums › General Questions › Nice plastic cover for a length of metal.
  • #170399
    Chris Denton
      @chrisdenton53037
      I'm trying to find something I saw a while ago. It's a plastic cover for made from plastic, I want it to fit on a piece of 5mm rod. I think it was like heat shrink tubing but with a solid end. Black with a shiny finish.
      Any ideas?!
      #23594
      Chris Denton
        @chrisdenton53037
        #170401
        pgk pgk
          @pgkpgk17461
          You can get heat shrink and cold shrink end caps for sealing cable ends but I'm guessing you want something a little thicker and ordinary ferrules should fit the bill either a tight stretch fit or a dab of adhesive. **LINK**
          #170402
          wheeltapper
            @wheeltapper
            it sounds more like a plastic coating melted on.
            it comes as a powder and you heat the metal and dip it in the powder.
            I cant remember the name offhand but try google for plastic coating .
            I,ll look tomorrow, I'm too tired now.
            Roy.
            edit
            look here
            http://www.polydip.com.au/content.php?cms_id=3
            Edited By wheeltapper on 22/11/2014 22:15:16
            Edited By wheeltapper on 22/11/2014 22:18:56
            #170405
            Ian P
              @ianp
              PVC end caps are readily available but whether they will be suitable will depend on how long your need to be.
              I have used PVC caps that look just like the ones in this link. I collected them ages ago as they were supplied as dust caps on some pneumatic components. They were a snug fit on 5mm rod and about 15mm long.
              http://www.tecni-cable.co.uk/Products/PVC-End-Caps-Vinyl
              Ian P
              #170412
              John Shepherd
                @johnshepherd38883
                Perhaps it was a plastic dip you have seen. The link shows a DIY solution from Frost Automotive Restoration.
                Or, depending on your application, you could make end caps from Sugru and cover the length with heatshrink?
                Edited By John Shepherd on 23/11/2014 07:13:19
                #170420
                  It's quite hard to get a good finish with Sugru, much patience and a wet finger was needed to do THIS repair.
                  I think it would work well if you can find a way to mould it, any suggestions for a release agent?
                  Clive Hartland
                    @clivehartland94829
                    There is an adhesive heat shrink tubing which i use regularly for making plugs waterproof. This will seal at the ends though you will not get a rounded seal.
                    #170425
                    Bazyle
                      @bazyle
                      There are lots of these sort of caps used in industry for a particular product initially that then get used elsewhere. For example the RF connectors in cable TV street cabinets have plastic caps when new which fit a 10mm rod. The SMA type of RF connector used in other equipment used one for1/4 inch.. SMB connectors will be smaller at 3mm. I used to bin loads of them.
                      So you need to thnk of a mass produced component that is 5mm and needs a protective cap. Then find who is using them and chucking away the end caps. I can only think of knitting needles .
