Mystery tool.
Mystery tool.
Home Forums Workshop Tools and Tooling Mystery tool.
  • #260084
    sparky mike
      @sparkymike
      #18216
      sparky mike
        @sparkymike
        #260085
        Phil P
          @philp
          It could be used for squashing a rubber hose to prevent flow through it. That might be why the lower round bar can be removed so you can get it around the hose.
          Phil
          #260086
          sparky mike
            @sparkymike
            I have had this tool lying around in my workshop for some time now, but do not have any idea of its purpose.
            The two squares revolve and are marked 25 on one end and 32 on the other. They lock in place with a detend ball and spring. The distance between edge of sqares and the removeable steel rod alters when you rotate the squares.
            It looks too good to be home made.
            Puzzled,
            Mike.
            #260087
            sparky mike
              @sparkymike
              Hi Phil,
              The gap between steel rod and the "U" pieces is only around 1/16" or less, so rubber tube is not a possibility I dont think.
              Mike.
              #260090
              john carruthers
                @johncarruthers46255
                A leaf spring compressor?
                #260091
                sparky mike
                  @sparkymike
                  The steel rod is 31.5 mm diameter, which could have a bearing on the 32 stamping on the square.Perhaps there was an alternative steel rod of around 25mm. that could be used with the 25 stamped position.
                  The maximum diameter that could fit in the hoops is 34mm.
                  I had thought that the tool could have been used for putting a loop in narrow strips of steel.
                  Mike.
                  #260104
                  Brian Wood
                    @brianwood45127
                    Hello Mike,
                    ​I think you are right—-this might have been an erectors tool to put 'joggle' bends in steel strip that is a traditional feature of Cheshire style field fences. The neat flat overlap joints could not be preset before erection and together with a blacksmiths leg vice, they could be easily made on site.
                    ​The welds look to be gas welding too, so it is an older tool.
                    Brian.
                    #260107
                      Posted by sparky mike on 09/10/2016 07:44:15:
                      Hi Phil,
                      Mike.
                      I agree with Phil – it looks very much like a tube clamp to me as well. We had similar in the school chemistry lab when I was a nipper. The rubber tube goes between the rollers and the clamp is tightened to throttle or stop the flow of a gas or liquid. They're much simpler to fit into a temporary set-up than a proper valve, and are unlikely to leak.
                      It's hard to tell from the photo how big it is – what are the dimensions? Edit – sorry daft question, you've already given the dimensions.  They're about right for it to be a tube clamp.
                      Edited By SillyOldDuffer on 09/10/2016 10:44:35
                      #260111
                      Roger Provins 2
                        @rogerprovins2
                        Looks very like a tool we had to squash closed a brake flexible coupling whilst working on the brake cylinders.
                        Roger
                        #260135
                        Nicholas Farr
                          @nicholasfarr14254
                          Hi Sparky Mike, I have to agree with Phil P to a certain extent, that it is a pipe squeeze off tool **LINK** only your one is for 25mm and 32mm MDPE water pipe **LINK** The idea is you select 25 or 32 for the size pipe you are squeezing and in that way you don't over nip the pipe to cause damage, but it will stop water from flowing while you effect a repair or an alteration.
                          Regards Nick.
                          #260137
                          Nicholas Farr
                            @nicholasfarr14254
                            Hi, a demo of how to use a pipe squeeze off tool **LINK**
                            Regards Nick.
                            #260240
                            sparky mike
                              @sparkymike
                              Hi Nick and all other replies. Yes it is a water pioe squeeze off tool. I found one nearly identical on that well known auction site, except you could adjust it for six different sizes of pipe. Good value for £2.00 at a boot sale!!. I shall just hang it up for emergencies if the water main develops a leak.!!
                              Many thanks for replies,
                              Mike.
                              #260254
                              Brian Oldford
                                @brianoldford70365
                                That's assuming your water feed is a 25mm and 32mm MDPE pipe, A bit trickier if it's iron. frown
