Mystery tool
Mystery tool
Home Forums The Tea Room Mystery tool
  • #511081
    Grindstone Cowboy
      @grindstonecowboy
      Sorting through some boxes and found this tool. Now, I know what it is and what it does, but thought others might be interested in having a guess. Maybe we could start an Advent Calendar of mystery tools?
      Rob
      Edited to get the photos in the right place…
      Edited By Grindstone Cowboy on 01/12/2020 17:36:01
      Grindstone Cowboy
        @grindstonecowboy
        Can you say what it’s for?
        #511083
        Howard Lewis
          @howardlewis46836
          Nut Splitter?
          #511084
          Grindstone Cowboy
            @grindstonecowboy
            Sorry Howard, it is not.
            Rob
            #511086
            Bo’sun
              @bosun58570
              Do either of the anvils rotate?
              #511088
              John MC
                @johnmc39344
                It looks like a tool for lubricating leaf springs. The anvils spread the leaves of the spring so grease can be pumped in to it. The version i had had a large screw down greaser on the end of the threaded bit.
                Howard Lewis
                  @howardlewis46836
                  Tool for removing vice jaw screws?
                  #511092
                  peak4
                    @peak4
                    Posted by John MC on 01/12/2020 17:46:21:
                    Agreed John, I'd been keeping my eyes out for one at autojumbles, but eventually changed to parabolic from elliptical springs on the Landrover, so no longer needed one.
                    Do a Google search on Terrys leaf spring greaser or something similar.
                    Bill
                    #511093
                    ega
                      @ega
                      I don't know and, seemingly, neither does Google Image Search.
                      #511095
                      Brian H
                        @brianh50089
                        Peak4 has it cracked, it's for separating leaf springs so that grease can be applied using the grease nipple on the screwed portion.
                        #511096
                        Grindstone Cowboy
                          @grindstonecowboy
                          Yes, the anvils do rotate, and John and Bill are absolutely correct, it's a Terry's leaf spring greaser. Well done to you both.
                          Rob
                          Edit – And Brian too – was still typing when you posted.
                          Edited By Grindstone Cowboy on 01/12/2020 18:17:19
                          #511097
                          Howard Lewis
                            @howardlewis46836
                            Ah, hadn't spotted a grease nipple. So that explains the slot in the moving Vee.
                            +1 for a leaf spring greaser.
                            That brings back some memories!
