Jeremy,
You will also need to check whether or not the contactor is fitted with a coil suitable for the higher 3 phase voltage or for the lower single phase voltage. If the former, then it will not pull in when used with 230VAC. Replacements are normally readily available from most industrial electrical wholesalers or distributors.
In addition, as Brian advises, you should always get your work checked,tested and formally certified by a suitably qualified and competant electrician before connecting any equipment to the supply.
